![]() | Home > Maintenance & Mods (L322) > Locked out of my 2011 RR Vogue |
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 ![]() ![]() ![]() |
it is actually exposed and easy enough to access the starter from behind the driver side wheel, i did it whilst trying to correlate voltage drop from battery > starter then battery > relay/trigger> starter
Giffer2018 Member Since: 25 May 2020 Location: West Yorkshire Posts: 63 ![]() ![]() ![]() |
Still not opened getting ready with big hammer!
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1324 ![]() ![]() ![]() |
I've just read that when you turn the key in the door you have to pull the handle at the same time. Worth a go. |
kevinp, yep tried that in various combinations -----------------------
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Others have opened the bonnet by removing the left (front) inner wheelarch (after removing the wheel) and then gaining access (with tools) to the two bonnet release cables/mechanisms. Could be a battery disconnect procedure may be in order... .
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
Just remembered my similar condition - Car Lock smith?
Joe90, Merchy, Yep locking wheel nut is in car together with Jack.
An addition to my post above, I forgot, at the time the cable for the outer door handle was broken (Drivers door ) just spoke to daughter, she said, quote -
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7966 ![]() ![]() ![]() |
I’m not sure that’s gonna work if the car is double locked…. Perhaps the only thing to go for is the bonnet catch, might be hard to pull though.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
AA are pretty good at breaking in to cars.
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 615 ![]() ![]() ![]() |
There is a way to open the boot lid and get in. DO NOT smash a window and DO NOT have a locksmith destroy your door lock barrel.
Think he’s tried that already….
Neither will work on a superlocked / double locked car. Ask me how I know ![]() But the trick I'm referring to, works every time and is a good insurance policy to know about it... |
Hopefully he can use it to get in then. Then carry on sorting potential battery issues from there.
