Home > Technical (L322) > Removing ball joint - at wits end
Page 7 of 7 <1234567
paul70
Well reassembly infinitely easier than dismantling. I'm about knackered for today but going to jack up and soak everything ready for tomorrow for doing the near-side.
Post #570502 21st Oct 2020 2:47pm
paul70
Did nearside today. What took me off and on 3 days to do off side (probably a total of about 5-6 hrs) took me only 1.5hrs to do near side. Very satisfying and a lot easier when you know what your doing Smile
Post #570658 22nd Oct 2020 3:19pm
Rangie4fun
Austria 2013 Range Rover Autobiography TDV6 Barolo Black
First of all many thanks to all contributors for sharing their experiences. Very helpfull in diagnosing and tackle the job. Thumbs Up Bow down
Had a rattle every time I hit a pothole. MOT (Pickerl in Austria Laughing) didn't find the cause, neither myself. No play on the ball joint!! even not on the MOT friction plates! Only to discover a worn ball joint after splitting it from the arm (to press in new bushes). So ordered these ball joints (Lemförder) and did the job this week on an afternoon. Had WD40 on it in the days before. Since the Torx 50 bolts are very hard to get loose I bought a decent Hazet Torx 50 socket and used my impact wrench on a very low pressure (max 4,5 BAR) to "hammer" it loose. Very important: low pressure!! It's only to "cut"te rust by vibrating so alternately convert the direction (1 sec R, 1 sec to L). Four bolts came loose easily without damaging anything.
Getting the ball joint out: removed most of the rust by wire brush and used a lot of WD40. Using the chisel on the ears did the job. Be carefull not to seize the ball joint in it's seating so alternate frequently between the two ears.
All done in situ (only removed caliper, disc and heat shield). Both sides took about 3 hours including tea break.
Very happy with a smooth ride again Very Happy
Post #570849 24th Oct 2020 9:17pm
ur20v
A Trap
Please don't use an air chisel on your ears, the noise alone will be very harmful lol!
Post #570876 25th Oct 2020 11:28am
Onebounce
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Santorini Black
Just started the same job on my L322. Great tip here about using an air chisel on the ears of the ball joint to get it out. Took about 1/2 hour, going steady with the chisel on both ears and out it came. My RR is an 05 with nearly 200k miles, so replacing both arms and the steady bar, both sides - that’s 6 control arms and 8 ball joints - although not all ball joints are created equal !
Parts not too expensive, just bloody hard work to get it done - so far only one arm and one ball joint replaced and I’m about 5 hours in. Also, using Plusgas as the release agent, not WD40.
Also doing a gearbox oil change as about 70k miles since last changed.
Post #617738 27th Dec 2021 7:17pm
Ajmngn
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Watch this from about 3:45 in. It’ll make you cry! 🤣
?si=oF5ojw1Ao2HCX9Cy Andy
2010 4.4TDV8 Vogue SE in Santorini Black with Ivory interior
2017 Audi SQ5 3.0 V6T Quattro in Volcano Red
2001 Audi Allroad 2.5 TDI manual with low-range in Highland Green (Currently SORN whilst undergoing some serious restoration!)
Post #672856 6th Sep 2023 11:34pm
Ajmngn
I did this job over the weekend. I cannot emphasise enough how much of a pig this job is. I had to get medieval on mine and basically bashed the hell out of the ball joint from above with a pointed chisel and a lump hammer. It took what felt like forever, but I think I was 60-90 mins going at each one.
Getting the wings to detach ever so slightly seemed to help (though this could’ve been entirely a placebo) and it took what seemed like forever to get the thing to start budging. However, once I could see that there was a slight gap appearing between the flange of the ball joint and the hub, it was just a matter of getting good contact and keeping going.
My top tips:
- lump hammer a must.
- chisel can’t be too long or the wheel arch gets gets in the way of a good swing.
- axle stand to support hub weight and ensure full force of hammer blows going into ball joint.
- fewer quality impacts much more effective than more impacts that get wasted. Take the time to position chisel properly. Don’t waste your energy taking swings that are wasted.
- spray, respray, and respray again with good quality penetrating fluid.
Good luck!! Andy
Post #676870 30th Oct 2023 8:35pm
garyRR
I notice on the linked YouTube video a) how clean the ball joints are - can't have been in the knuckle that long and b) dry climate
For those of us in the UK and the rest of Western Europe, unfortunately road grime, salt and whatever else practically welds anything on the underside of these cars.
Mine were done in the summer. Observations:
- the lower control arms aren't too difficult to get undone. You'll definitely need a good impact wrench or air wrench to get the bush bolt undone though
- heat is your friend
- if your torx screws are so far gone, there's no chance of getting them out. The heads of 4 out of the 6 screws (3 each side) had basically turned into cheese. No amount of gently gently would help. In this scenario, unfortunately, it's knuckle off and either weld a nut or pillar drill them out so that the holes can be re-threaded
- popping the driveshaft out will give you much more room
- there's no reason a Pitman arm puller or a ball joint splitter won't help in this scenario
- using brake fluid and acetone to eat away and loosen the ball joint is a wise move
- I'd have liked to try my SDS on hammer function - somehow I feel like it may have made light work 2015 Range Rover Autobiography 4.4 SDV8
Post #676882 31st Oct 2023 12:26am
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
As I mentioned in a related post I did the driver's side this weekend.
The worst job I have ever done on any car. Ever Censored
In the end, we had to gut the ball joint and press it out using a homemade device involving a threaded bar, and simply wound it down and out.
My car´s been in Spain for 50% of its life, my hopes of it being a relatively simple job had long since disappeared by the 6th hour of hammering at the ball joint.
But the job is done and well worth it Rolling with laughter
 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #676914 31st Oct 2023 12:55pm
Ajmngn
WOW! I thought I had a bad time with mine but you seem to have won this thread with 6 hrs!!
This was the state of mine once out, no need (thankfully) to gut them and press out like you…
 Andy
Post #677030 1st Nov 2023 7:22pm
bastion
Just done one side took most of the day. rear arm got sorted with air chisel (wear ear muffs).
For me what really took the time was the front arm ball joint, had to alter a splitter to give it wider jaws and pop.
Post #677144 3rd Nov 2023 10:27am
