![]() | Home > Technical (L322) > Removing ball joint - at wits end |
paul70 Member Since: 06 Mar 2018 Location: North Yorkshire Posts: 101 ![]() ![]() ![]() |
Well reassembly infinitely easier than dismantling. I'm about knackered for today but going to jack up and soak everything ready for tomorrow for doing the near-side.
Did nearside today. What took me off and on 3 days to do off side (probably a total of about 5-6 hrs) took me only 1.5hrs to do near side. Very satisfying and a lot easier when you know what your doing |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Please don't use an air chisel on your ears, the noise alone will be very harmful lol! |
Onebounce Member Since: 27 Jan 2014 Location: London Posts: 1 ![]() ![]() ![]() |
Just started the same job on my L322. Great tip here about using an air chisel on the ears of the ball joint to get it out. Took about 1/2 hour, going steady with the chisel on both ears and out it came. My RR is an 05 with nearly 200k miles, so replacing both arms and the steady bar, both sides - that’s 6 control arms and 8 ball joints - although not all ball joints are created equal !
Ajmngn Member Since: 25 May 2021 Location: Cambridgeshire Posts: 209 ![]() ![]() ![]() |
Watch this from about 3:45 in. It’ll make you cry! 🤣
I did this job over the weekend. I cannot emphasise enough how much of a pig this job is. I had to get medieval on mine and basically bashed the hell out of the ball joint from above with a pointed chisel and a lump hammer. It took what felt like forever, but I think I was 60-90 mins going at each one.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
I notice on the linked YouTube video a) how clean the ball joints are - can't have been in the knuckle that long and b) dry climate
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 436 ![]() ![]() ![]() |
As I mentioned in a related post I did the driver's side this weekend.
WOW! I thought I had a bad time with mine but you seem to have won this thread with 6 hrs!!
bastion Member Since: 17 Oct 2018 Location: uk Posts: 30 ![]() |
Just done one side took most of the day. rear arm got sorted with air chisel (wear ear muffs).
