Home > Maintenance & Mods (L405) > Just in time for winter...remote climate retrofit |
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 911 |
Yes, should be a 2 minute job now when the bits arrive Paul
16th Aug 2021 1:47pm |
I had it on my D4 and I think when the cold weather comes I would miss it too. Its nice not having to wait to defrost windows Paul
16th Aug 2021 7:54pm |
All done, fitted and programmed and wiring for the snow . Thanks again to Kev for the writeup Paul
7th Sep 2021 10:02pm |
154JON Member Since: 31 Mar 2019 Location: Essex Posts: 129 |
Had all summer to sort my retro heating fit after i didnt getting it going last winter due to an open circuit on the aux water pump but i thought i would wait till i could stand in the cold again to try and sort it , would anyone know if 12v and an earth should bring the pump to life, i have noticed on pictures of the pump that it has 3 pins in the plug socket but only 2 wires feed it. Thanks for any info. |
7th Oct 2021 8:39am |
G3 TUC Member Since: 31 May 2021 Location: Cleethorpes Posts: 5 |
Hi all fitted the parts and paired remote but it will only work if am stood next to back piller any one any ideas as to why
5th Jan 2022 2:49pm |
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 203 |
Check the antenna connections |
7th Jan 2022 6:08pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 735 |
I don't get a very good range on mine to be honest. It's fine for my needs, and will work between my hallway and car, but if I move into my kitchen, it doesn't reach. On my old L320, the range was crazy. I could have been in the middle of the supermarket and it would reach out to the car park. Kev
7th Jan 2022 6:14pm |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 |
This is bloody genius! Thank you, Kev. Will be checking if I have FBH and, if I do, I feel an upgrade coming on. What do I put here then? |
7th Jan 2022 9:34pm |
No problem
7th Jan 2022 10:34pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3055 |
this any help?
13th Jan 2022 11:17am |
This morning's frozen FF reminded me to at least do this bit. All looks good. Have set it to run tomorrow morning as a test. Assuming it works - can't see why it won't - I'll be buying the bits to add the remote. Thanks again for this @knwatkins it's a great post. What do I put here then? |
13th Jan 2022 3:56pm |
Ran my test timed climate this morning.
14th Jan 2022 11:45am |
Strange. My windscreen is always defrosted by the time I get out to the car. Mind you, I think last night was particularly chilly. Just whack your heated front screen on. Should be melted in a few minutes Kev
14th Jan 2022 11:05pm |
My L322 used to always clear the screen too.
15th Jan 2022 11:12am |
