Home > In Car Electronics (L322) > Fitting my Naviplus / air play unit
Page 9 of 13 <123 ... 8910 111213>
davethomas83
United Kingdom 2002 Range Rover HSE Td6 Baltic Blue
Thanks again,
Just for my own sanity, I’ve just put it all back to factory again, that works ( phew ), introduced the new harness cable ( with no new modules plugged in ), and still works at the stage.
So it’s something to do with whatever I’m doing screen side, or some kind of setting - at least I know I’m not looking for a breakers with a spare screen at least 😂
I’ll wait to hear what Navi come back with - I’m being to smell something faulty with one of the new components
Post #623312 11th Feb 2022 6:16pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Oh that is excellent news. At least you can close it up and just fiddle below Mr. Green
Fingers crossed it is just a dip switch setting.
Post #623315 11th Feb 2022 6:27pm
davethomas83
Hazar
Now just to put it all together again! For now pub and pint !
Thanks Bl4ckD0g for input. I’ll right up a little “My Experience” just for reference for others.
Post #623326 11th Feb 2022 7:14pm
Bl4ckD0g
Yay!!! Fantastic news. Looking good. Well done.
It was my pleasure.
Post #623327 11th Feb 2022 7:18pm
Full-fat-Lance
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Orkney Grey
With this unit, can you choose which side the app buttons are on? Usually they are on the drivers side ie right rand side in uk but the picture above shows them on the left?
Post #623425 12th Feb 2022 2:28pm
davethomas83
I imagine it configurable - I’ll double check when I go out shortly.
The OCD in me prefers it on what would technically be the wrong side I guess
Post #623450 12th Feb 2022 4:36pm
Full-fat-Lance
Thanks. This could well be the first mod I do once I’ve found a car!
I guess the logic is having the controls nearest to the driver.
Post #623451 12th Feb 2022 4:55pm
bigben
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
I am sure I am missing something but how do I get the WiFi connection up and running.
Hopefully nothing to do with dip switches as the units are all deeply embedded in the dash and no way they are coming out again!
The other news from my install is the airbag light fixed itself when the end panel with the switch was refitted. Really recommend this system has made my commute much more agreeable.
Ben 2011 TDV8 Vogue
2007 TDV8 Vogue
Post #623542 13th Feb 2022 12:04pm
Full-fat-Lance
I’ve read earlier in the thread that you just connect to it via Bluetooth and it then sorts the wireless connection on its own.
Post #623563 13th Feb 2022 1:39pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Hi Lance
How did you get on with the Naviplus, are you pleased with it? is it worth the money? I can pick one up as I`m in Australia and can claim the tax at the airport.
Cheers
Post #624028 17th Feb 2022 10:31pm
Full-fat-Lance
I’ve not got one yet! I’m still looking for the car first Laughing
I’m sure others will be along soon with their opinions but everything I’ve read has been positive save for the naff instructions.
Post #624033 17th Feb 2022 10:54pm
Andy2986
United Kingdom 2011 Range Rover Vogue TDV8 Barolo Black
Ben
If you have the Wi-Fi unit fitted (it’s an extra ) you just sync your phone via Bluetooth and it does the rest. 2011 4.4 TDV8
2000 4.6 P38
1998 D1 300tdi
Post #624036 17th Feb 2022 11:12pm
garyRR
Forgive the potentially inflammatory comment or is anyone else with me on this or am I missing something?
The Naviplus kit is nearly £1,000 last time I looked and it is a horrendous install, as exemplified by this thread (my worst install was the tow bar - 90 minutes the instructions say!!!!). The whole dash and front fascias need to come off to fit is.
As far as I can tell, what Naviplus gives you is Android Auto or Apple CarPlay on the existing screen in the car.
But what i cannot understand thus far is why you would want to spend £1,000 plus many hours installing something on a low resolution screen, when you can just run car mode on your phone in a good quality car mount. And many modern phones have screen sizes getting close to the size of the screen in the car, at MUCH higher quality. So, what is the benefit? What am I missing over spending £15 on a car mount? 2015 Range Rover Autobiography 4.4 SDV8
Post #625748 9th Mar 2022 12:38am
Tinman
Not fitted mine yet? the cost was under £700 with the extras. I don't think you have to touch your phone after its Bluetooth paired and you can control other functions as before from the steering wheel controls.
Those that have fitted it say it's worth the money?
The instructions that come with it seem easy to understand, from what I can see it does not require any soldering just plug ends to connect?
I have fitted three cars with deployable steps and JLR instructions are a lot harder to follow on removing the trim?
Post #625751 9th Mar 2022 6:00am
although this naviplus system is integrated and mostly works ok, i've always thought it was way to expensive...
there are headunit replacements for £300'ish or you could get one of these,
this excellent thread started by baltic blue shows how easy it is to fit and to remove the unit,
https://www.fullfatrr.com/forum/topic61372.html
these unit normally retail around the £200 mark but as it happens there is an ebay seller selling them at £133..
https://www.ebay.co.uk/itm/203860081968 ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #625757 9th Mar 2022 9:21am
