Home > In Car Electronics (L322) > L322 2007 Android Headunit Options
Page 1 of 5 12345>
mdis89
So... I have searched the forums, and found quite a few posts, most a few years old now, with no real answers to what im looking for. So my apologies if its, yet another android headunit thread Laughing
So... What are people using? And any cons of each option?
I dont mind losing the 4x4 info screen, as long as steering control still works really.
I also didnt realise (some?) BMW headunits will work too? (is this all just plug and play, or rewiring required?
So far from searching the forums/google, it looks like:
https://www.erisin.com/products/erisin-es8...dvr-canbus
https://www.iceboxauto.com/rangerover-vogu...play-rr011
https://www.amazon.co.uk/ZWNAV-Replacement...S78J4?th=1
https://www.canavie.com/1025-android-car-s...37195.html
The prices seem all over the place too - So if anybody has experience with the above, including fitting - It would be great to hear your guys advice.
Post #632172 18th May 2022 8:40pm
Dommo
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Not heard of any of the above, but have recently successfully installed a navtool unit into my 2007. Not technically an android headunit, but gives android auto which is what I was after, and retains all of the factory functionality.
Post #632174 18th May 2022 9:01pm
mdis89
Ah that was potentially another option - Is that from https://www.navtool.com/ ?
I dont find the existing touchscreen in the car, super-responsive at the moment, so i think it would just be frustrating that taps/swipes wouldnt recognise sometimes.
The navtool sites not loading for me at the moment, how much are they?
Post #632175 18th May 2022 9:06pm
Dommo
Yeah that's the one... website does appear to be a little bit broken at the moment. Doh!
I paid $381 delivered for a version 5 unit - they were on clearance. The only difference I've seen with the navtool 6 is the 5 doesn't have the wireless connectivity. That's what pushed me into buying really - I only use it on long journeys so plugging in makes no difference to me - I've routed the USB cable up into the arm rest cubby.
From memory, the full price of the version 6 was something like $550 delivered, but don't take that as gospel.
Fitting was very much plug and play.
Post #632178 18th May 2022 9:43pm
mdis89
Seems like a good way for screen mirroring, or adding extra HDMI inputs on to the main screen.
I just cant imagine the touchscreen being a good experience, its already a little unresponsive at times.
I think ill most likely go with the Erisin unit, seems a bargain (https://www.erisin.com/products/erisin-es8153b-1025-android-100-car-stereo-for-bmw-e53-e39-m5-carplay-auto-gps-tpms-dab-dsp-dvr-canbus)
Look like @danwilderspin here has had a positive experience with it too: (https://www.fullfatrr.com/forum/topic54042.html?highlight=erisin&start=30)
Post #632248 19th May 2022 5:21pm
Dommo
Yeah, if you've got issues with the OEM touchscreen, a replacement device is much more logical
Post #632290 19th May 2022 11:25pm
mdis89
So, i went with the IceBox unit in the end https://www.iceboxauto.com/rangerover-vogu...play-rr011
Bit of a pain to install, but just about managed it - However i have a couple of new issue's, and would be great to get some advice, (most likely relating to disconnecting battery i presume).
- Unable to lock/unlock car with key anymore
- Top/Bottom glove compartments no longer open
- Steering wheel position isnt raising for easy entry anymore
- Now getting a Suspension Fault notice (All seems to actually work correctly though)
Is something not connected? Or do i just need to clear any error codes? Disconnect battery for a short while?
Post #638117 28th Jul 2022 9:53pm
Googs
Australia
Did you fix any of the new problems?
All you need to do is clear all the new soft codes.
most scanners will do this for you.
Post #638306 31st Jul 2022 2:37am
mdis89
I cleared the codes, but it didn't immediately get rid of some faults
However, most of the issues fixed themselves after a while of driving around.
Glove compartment is still not unlocking, however it turned out I blew a fuse. So I think the glove compartment switch needs replacing.
Suspension fault came back today, however... I'm sure the new headunit is draining the battery while it's off.
So just.a few things to keep an eye on really, but all is now we'll 😁
Post #638393 31st Jul 2022 11:01pm
Googs
Australia
Is the little Red light on console in front of hill decent switch turning off after about 10-15 min?
Suspension fault (air suspension inactive);have you checked for leaks on all 4 corners and the valve blocks, I have this problem at the moment, every 2nd day i get the (ASI) readout on dash. My fix is reseal air tank valve block!
I'm sure you should be able to adjust the glove compartment latch, just needing a little tweak.
So how do you find the new headunit ?
Post #638798 5th Aug 2022 9:27pm
Rjh112
I've got this unit, its sat in living room waiting for my time off. Any hints on fitting? I've looked at instructions and was assured that its all plug and play without pulling cables through the car, obviously the instructions are in broken English/asian which doesn't help
Post #639111 9th Aug 2022 2:45pm
Danwilderspin
Read this :
https://www.fullfatrr.com/forum/topic54042...p;start=30
Get the Erisin it’s great
I have a rca to most adapter for sale if you want as close to plug and play as possible.
If not get on eBay and get an infinity or jbl 6 channel amp Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #639351 11th Aug 2022 11:29pm
mdis89
I was super tempted with the Erisin unit, but its slightly curved isnt it?
The icebox one fits perfectly, and no regrets (so far) Very Happy
@googs - Is suspension fault, Air Suspension Inactive 2 different warnings? Ive only had "Suspension Fault", all be it, everything is working fine. (It disappears on its own after a few days).
@Fozziebeard - The instructions Icebox supplied were really lacking. I found another long post on another forum which i found really helpful for the order of which panels should be taken off etc: https://www.rangerovers.net/threads/removi...al.342997/
Post #639614 14th Aug 2022 10:36pm
Danwilderspin
It is curved you are correct I think you could infer it 3d printed flat but it’s not off the self then Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #639619 14th Aug 2022 11:47pm
Danwilderspin
That’s interesting that wasn’t around when I started - he claims you lose no functionality can you set he time and date on the dash and the clock?
 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #639620 14th Aug 2022 11:54pm
Page 1 of 5 12345>
