![]() | Home > In Car Electronics (L322) > Fitting my Naviplus / air play unit |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
I have tried it plugged into the lightning connector that's when it is showing on the screen but no sound, so as you say the head unit has not switched off the car radio and should be in AUX?
=dj= Member Since: 24 Oct 2020 Location: New forest Posts: 67 ![]() ![]() ![]() |
The Naviplus system and the factory head unit are both always running all the time.
Thanks for the info DJ
When the tech demonstrated integration with his Android phone, did he use the touch screen for input at all? Or did he just use his phone's screen to input options?
Hi, DJ what do you think about the screen that I posted? |
That's looking exactly how it should! Clearly the video and audio side it working properly |
Hi Mate what you are saying and what I am thinking are the same, it all points to the installation.
No problem, Alex!
Rackers Member Since: 04 Apr 2022 Location: Portsmouth Posts: 93 ![]() ![]() ![]() |
Dual view version of the unique-ad system available for preorder.
Faukstad Member Since: 27 Dec 2021 Location: Oppland Posts: 66 ![]() ![]() ![]() |
Gents, how do these systems work with back seat entertainment, for those of us who have that.? |
Full-fat-Lance Member Since: 06 Feb 2022 Location: Essex Posts: 149 ![]() ![]() ![]() |
The unit doesn’t really interact with the RSE. Certainly nothing from the unit can be output on the RSE displays. At most, I expect the RSE can select the aux input to be able to listen to whatever you’re playing via the unit.
For anyone that is thinking about buying the Unique-ad dual view kit, I installed it last week and it works great as advertised. I used a combination of their instructions as well as the ones that come with the Naviplus (that was posted to this thread) as well as some Youtube videos for extra help in taking various bits of the dash apart. I'd say the hardest bit is taking the screen apart, there isn't a lot of room in there but just take your time. It took two days with me doing other various bits in between but safe to say unless you've done the dash before, it isn't something you could do in one day. |
