Home > Technical (L322) > Aircon - off and on....
Page 2 of 6 <123456>
kevinp
Watching with interest JayGee. Mine has started to Censored about as well. Sometimes it will work more or less instantly or I might have to travel 3 miles or more to get a whiff of coolness.
Sometimes it starts to work after going round a sharp corner!!! Big Cry
Mine was meant to have had a new compressor not long before I bought it 2 years ago.
Post #635241 23rd Jun 2022 1:38am
JayGee
Just looked as Sam’s motor and machines YouTube vid on compressor replacement and it looks a right pig of a job. Will likely get a garage to do it and if they are removing the fan I’ll get them to do the alternator as well as preventative maintenance now it’s gone past 140k 2012 TDV8 Vogue (L322)
Post #635245 23rd Jun 2022 6:59am
Superspoons
Mines off to to be tested/re gassed today.
I'll take all the points made above onboard and ignore the chippy ones - its just not needed. We are all here to help each other and different experiences lead to a solution normally. Gavin
1998 Defender 50th Anniversary - GB168 - preparing for sale
Post #635246 23rd Jun 2022 7:46am
DrRob
Had mine done at Glenrands by the ex LR Techs there. Supplied from Advanced Factors so no mark up for a Genuine parts box and the same make (Nissens)! If you use the, tell them I sent you. Have loan car/collection service. Can't rate them highly enough Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90
Post #635247 23rd Jun 2022 8:08am
JayGee
How much was the job at Glenrands? 2012 TDV8 Vogue (L322)
Post #635251 23rd Jun 2022 8:12am
DrRob
Best give them a ring. Talk to Ross. They are now site sponsors Thumbs Up
I won't go anywhere else now and I've used a lot of independents over last 20years!
https://www.fullfatrr.com/forum/sponsors.php
www.glenrands.co.uk Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #635252 23rd Jun 2022 8:14am
JayGee
I keep hearing good things about them and even though it's a fair distance from me if I can get a courtesy car and leave it with them for a few days with a list of jobs it's going to minimise my downtime. 2012 TDV8 Vogue (L322)
Post #635253 23rd Jun 2022 8:18am
DrRob
Exactly what I do (albeit I'm closer). I use their Freelander 2 Auto TD4... Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #635255 23rd Jun 2022 8:24am
JayGee
When I turned the engine on the condenser temp started to drop down quickly but after a few seconds it was back up to the internal temperature so no cooling at all even after a 5 min drive. 2012 TDV8 Vogue (L322)
Post #635266 23rd Jun 2022 11:19am
Phoenix
That pressure is way too low, what was it when you started it up?
ETA what is the static pressure and temperature (I.e. ignition on, engine off, climate control off) for an ambient of 25 it should be around almost double your measurement above.
Post #635282 23rd Jun 2022 2:36pm
JayGee
Will check later when I start it again 2012 TDV8 Vogue (L322)
Post #635283 23rd Jun 2022 2:37pm
JayGee
9 hours later the system is at 6.3Bar with ignition on and not running and doesn't change. Evap temp is 35deg and hotter than the in car temp and only comes down when you switch off the AC i.e running the AC makes the car interior warmer Embarassed . 2012 TDV8 Vogue (L322)
Post #635295 23rd Jun 2022 6:47pm
Phoenix
In that case, a recover, recharge & extended leak check should sort you out, static pressure should be around 8 bar at that temperature, it only needs ~10% liquid refrigerant to give a similar reading to the one you have, even if you get a leak-free test, I strongly suggest that some UV compressor oil is added to the system to aid any future diagnosis.
Post #635297 23rd Jun 2022 7:40pm
JayGee
Thanks for the advice - so I should not book it in for a new compressor then? 2012 TDV8 Vogue (L322)
Post #635299 23rd Jun 2022 7:57pm
Phoenix
A static pressure/temperature check eliminates all other components other than the refrigerant, in your case, the pressure is low for the stated ambient temperature, therefore the first thing to do is recover, recharge and leak check - with a static check, the pressure is equal throughout the system, even one with restrictions, faulty control valves etc. If the pressure was in the expected range for the ambient temperature, then it would warrant further investigation, possibly compressor or filter-drier replacement but with a pressure I'd expect to see with a ten degree lower ambient, then there's clearly something wrong with the refrigerant charge level. I'd hazard a guess that you have about a 40% loss - and that is a guess.
Post #635301 23rd Jun 2022 8:20pm
