Home > Technical (L322) > Aircon - off and on.... |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2710 |
Just looked as Sam’s motor and machines YouTube vid on compressor replacement and it looks a right pig of a job. Will likely get a garage to do it and if they are removing the fan I’ll get them to do the alternator as well as preventative maintenance now it’s gone past 140k 2012 TDV8 Vogue (L322) |
23rd Jun 2022 6:59am |
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 374 |
Mines off to to be tested/re gassed today.
23rd Jun 2022 7:46am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4245 |
Had mine done at Glenrands by the ex LR Techs there. Supplied from Advanced Factors so no mark up for a Genuine parts box and the same make (Nissens)! If you use the, tell them I sent you. Have loan car/collection service. Can't rate them highly enough Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" New Defender D300 90 1974 Series 3 Lightweight = "Millie" My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
23rd Jun 2022 8:08am |
How much was the job at Glenrands? 2012 TDV8 Vogue (L322) |
23rd Jun 2022 8:12am |
Best give them a ring. Talk to Ross. They are now site sponsors
23rd Jun 2022 8:14am |
I keep hearing good things about them and even though it's a fair distance from me if I can get a courtesy car and leave it with them for a few days with a list of jobs it's going to minimise my downtime. 2012 TDV8 Vogue (L322) |
23rd Jun 2022 8:18am |
Exactly what I do (albeit I'm closer). I use their Freelander 2 Auto TD4... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
23rd Jun 2022 8:24am |
23rd Jun 2022 11:19am |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
That pressure is way too low, what was it when you started it up?
23rd Jun 2022 2:36pm |
Will check later when I start it again 2012 TDV8 Vogue (L322) |
23rd Jun 2022 2:37pm |
9 hours later the system is at 6.3Bar with ignition on and not running and doesn't change. Evap temp is 35deg and hotter than the in car temp and only comes down when you switch off the AC i.e running the AC makes the car interior warmer . 2012 TDV8 Vogue (L322) |
23rd Jun 2022 6:47pm |
In that case, a recover, recharge & extended leak check should sort you out, static pressure should be around 8 bar at that temperature, it only needs ~10% liquid refrigerant to give a similar reading to the one you have, even if you get a leak-free test, I strongly suggest that some UV compressor oil is added to the system to aid any future diagnosis. |
23rd Jun 2022 7:40pm |
Thanks for the advice - so I should not book it in for a new compressor then? 2012 TDV8 Vogue (L322) |
23rd Jun 2022 7:57pm |
A static pressure/temperature check eliminates all other components other than the refrigerant, in your case, the pressure is low for the stated ambient temperature, therefore the first thing to do is recover, recharge and leak check - with a static check, the pressure is equal throughout the system, even one with restrictions, faulty control valves etc. If the pressure was in the expected range for the ambient temperature, then it would warrant further investigation, possibly compressor or filter-drier replacement but with a pressure I'd expect to see with a ten degree lower ambient, then there's clearly something wrong with the refrigerant charge level. I'd hazard a guess that you have about a 40% loss - and that is a guess. |
23rd Jun 2022 8:20pm |
