![]() | Home > Technical (L322) > Aircon - off and on.... |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3380 ![]() ![]() ![]() |
Thanks - much appreciated! 2012 TDV8 Vogue (L322) |
Similar but not knowledgable to know what it means apart from there is no cooling at all and there is some pressure in the system and the compressor is drawing current. 2012 TDV8 Vogue (L322) |
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 176 ![]() ![]() ![]() |
Maybe you have a leak and system hasn't lost the gas completely yet. As the compressor is turning on.
Going off pressure readings alone can be deceptive, for air-conditioning to work properly, there needs to be enough condensable gas in the system so that there can be liquid formed under pressure - the 'high' side. It is possible for there to be sufficient pressure in the system for it to work in a narrow range of circumstances and not set a DTC. The readings presented in the screenshots also have a different ambient temperature so unless you know the temperature /pressure relationship for the particular refrigerant in use, they are meaningless as a comparison.
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2291 ![]() ![]() ![]() |
just found this one in the wiki, might help someone:
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3273 ![]() ![]() ![]() |
that's for a 2003 4.4 V8 petrol though. May differ to the 2011 TDV8. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1493 ![]() ![]() |
That's of the old BMW 4.4 and not the 4.4 TDV8. 2015 Range Rover Autobiography 4.4 SDV8 |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
I will jump in here and go a little off-topic, if I asked for advice and disagreed with the advice given, I would......
AC was working this weekend with the lower ambient temperatures than last week. Still going to get a regas and leak check this week though. 2012 TDV8 Vogue (L322) |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
Think that sounds like the best first move.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1357 ![]() ![]() ![]() |
Ditto, mine the same. |
don't mean to hijack, but these are my Iid tool readings yesterday. My aircon has been assessed to have no leaks but is still not very cold when needed. any comments? Is it the valve fault you reckon? it's a 2011 TDV8.
You might have all read this already….
Doesn't look like it's cooling at all with those evap temps - what was the heater control temp set to? 2012 TDV8 Vogue (L322) |
