|  | Home > Technical (L322) > Aircon - off and on.... |
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3404     | I've booked mine into Kwick  | ||
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631   | Aircon working 'ok' with a lower ambient is typical for low refrigerant charge, it isn't 'ok' of course, it's just that the lower ambient puts less of a load on the system as there's less heat to recover. Same goes for flinging it round corners, the liquid that is in the system gets thrown around and temporarily increases the system pressure against the orifice, so there is a high/low pressure differential, which is how the system works. | ||
| kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1364     | Interesting Phoenix, perhaps mine is just low on refrigerant then. It mirrors everything you have pointed out. | ||
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3404     | I also have this fault
 Aircon systems are not complex beasts, they haven't changed in basic design since 1933, patented in 1935 and brought to the masses by Packard in 1939. It is, of course, just physics - but the operating principle is often misunderstood due to the enhancements and complexity of the air handling systems it is installed in. BTW, it's not my main systems speciality, just one I'm very familiar with, especially at this time of year. | ||
 That is normally a transient fault and only affects the auto recirculation function - it will be overridden by a high aircon demand (or manual recirculation request) which will close the recirculation flap to aid fast cooldown to setpoint, once 80% of setpoint is achieved, then the recirculation flap will reopen, unless the air quality sensor prevents it. | ||
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3404     | 731g recovered, 880g recharge +10ml PAG oil. No leak with 20min vacuum leak test.
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631   | What was the ambient temperature when those screen shots were taken? | ||
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3404     | 18deg 2012 TDV8 Vogue (L322) | ||
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3404     | Not fixed......
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002     | Sounds like mine….. delayed air con….
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3404     | I'll not be keeping the car that long but don't fancy going through summer with no aircon. At the moment I get cooler air by turning off the aircon so not sure what's happening there? 2012 TDV8 Vogue (L322) | ||
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352     | It's a long winded job to change the compressor. Make sure you take it to a specialist   | ||
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3404     | I've seen the videos and It's just about possible to do it by removing the NS airbox but the workshop way is to remove the fan cowl. If it's the later I'll get them to replace the alternator as well. 2012 TDV8 Vogue (L322) | ||
| Posting Rules
