Home > Technical (L322) > Aircon - off and on.... |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4219 |
Good plan. You already know who I would recommend taking it to in Hampshire..
28th Jun 2022 8:37pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1316 |
Good you've gone through the steps but, I did say it'll be the compressor. Book time for the job at JLR is 4.5h. Expect an independent garage to charge 5h or so. Most garage rates seem to be £80ish per hour plus VAT so, call that £500 labour, plus £70 pressure test and recharge plus the part (and many garages won't let you supply your own) - I think cheapest you'll find the job is £900. As a reputable specialist, Glenrands will be more. So, if you're not planning keeping the car much longer then I personally wouldn't spend £1,000 getting the air con done. If you're planning on keeping it more than a year, then I definitely would because, you'll get 2 summers out of it. 2015 Range Rover Autobiography 4.4 SDV8 Last edited by garyRR on 28th Jun 2022 9:40pm. Edited 1 time in total |
28th Jun 2022 9:36pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2642 |
Just had my spreadsheet out pricing up my next car..... 2012 TDV8 Vogue (L322) |
28th Jun 2022 9:39pm |
An L405 SDV8? 2015 Range Rover Autobiography 4.4 SDV8 |
28th Jun 2022 9:40pm |
Just looked at Autotrader and there are a lot of late L322's on there for prices that are down quite a bit from this time last year but also mine is now worth so little it's not worth selling / trading in so may still get the compressor and alternator done and hang on to it for a while longer. 2012 TDV8 Vogue (L322) |
29th Jun 2022 8:26am |
Booked in at Glenrands for new compressor and alternator. Don't fancy gambling on a cool summer or an alternator on 140k. 2012 TDV8 Vogue (L322) |
29th Jun 2022 3:29pm |
Had a run out today but wasn't particularly testing the IC but when I got back I plugged in the gap tool and with the window open and the heater set to 22 I got this
1st Jul 2022 2:35pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Evaporator temperatures should be below 7 deg. C. Clearly the compressor and system are capable of achieving that, but not all the time. The current lower ambient will help as it will keep the low side pressure down which is possibly what causes the RCV to (mostly) work again. |
1st Jul 2022 8:23pm |
Back to not working this morning....... 2012 TDV8 Vogue (L322) |
2nd Jul 2022 12:49pm |
Not long to wait until your compressor change JayGee!
2nd Jul 2022 2:20pm |
@JayGee
3rd Jul 2022 1:17pm |
Should have had the alternator done when I had the belts, pulleys and tensioner done last year. Not letting another opportunity slip by to have some peace of mind….. 2012 TDV8 Vogue (L322) |
3rd Jul 2022 1:25pm |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 385 |
I'd get the alternator done at the same time as the compressor. I had my compressor replaced a couple of years ago (probably 9k miles) and the alternator went recently. It's expensive to replace it on its own.
5th Jul 2022 2:27pm |
New compressor fitted yesterday at Glenrands so have working AC at last! They advised against replacing the alternator so I took their advice. 2012 TDV8 Vogue (L322) |
22nd Jul 2022 8:33am |
