![]() | Home > My Range Rover > Back with another Supercharged |
Most welders will be absolutely fine, it's only HF start that cause problems, keep the 'ground' (actually +ve on most modern welders) close to the area being welded - have you considered gas brazing? it's not a structural part so will be OK and the temperature is a lot lower.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3327 ![]() ![]() ![]() |
Other then the heads being removed and a load of things disconnected under the bonnet, everything else is intact and connected on the car.
More parts arrived today |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1037 ![]() ![]() |
It's the little things |
Good find with the throttle body - we were warned off using 'fogging oil' due to the water content, Baby Oil is seemingly a good alternative, although it isn't something you'd want to use for cabin air leaks as it stinks... |
Yea, I chucked the fog machine and made a new smoke machine from some drainage pipe fittings a few months ago that I filled with baby oil. You’re not wrong about the stench though… it’s horrific when heated! 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Intersting I need to fix mine as some point didnt know you could get a replacement battery was going to make my own up so thanks David that saved me a bit of time Everything else is stating to look really good puts me to shame |
Cheers Sandy |
Torque wrench has arrived today along with the new head bolts.
strongstuff Member Since: 26 Jun 2019 Location: North Wales Posts: 44 ![]() ![]() ![]() |
Really pleased that Roland was as good as I was told he was! Can't wait to see this running now, very best of luck with the remaining work. 2008 L322 4.2 V8 SC Stornoway Grey 2006 L322 4.2 V8 SC Java Black |
Finally had everything I needed to get the heads back on today |
Nice one, the part I like is the hissing & wheezing when you turn the crank a few times by hand before checking the timing - even though you know it's correct! |
I’m looking forward to that but I must admit!
Everything was about timing this afternoon…
