Home > Maintenance & Mods (L322) > While we are down there.....
jackie-o
Netherlands
Hi all,
Hope everyone has had, or is still having, a good summer!
My 4.4 TDV8 is in the garage to change AC compressor and generator. Is there any other preventative work worth doing while half the engine is ripped out anyway?
As always, all advice is appreciated!
cheers RR Vogue 4.4 TDV8 - 11
Toyota Land Cruiser Prado - 02
LR Discovery 4 SDV6 -11 - Gone
RR Vogue 3.6 TDV8 - Gone
Post #639946 17th Aug 2022 4:09pm
Dolphinboy
check/replace tensioners.
Post #639950 17th Aug 2022 4:45pm
garyRR
Starter motor
Auxiliary belt (and pulleys/tensioner if required)
Oil cooler
Expansion tank
Gearbox service
Diffs and transfer box oil changes
Exhaust Gas temperature sensor on each exhuast manifold 2015 Range Rover Autobiography 4.4 SDV8
Post #639954 17th Aug 2022 4:51pm
jackie-o
Netherlands
Thanks!
Belts, pulleys and tensioners they will check as these are coming out anyway.
Is the starter motor located in the front?
Oil cooler gaskets already done about two years ago along with a new EGR....
@garyRR do you mean the expansion tank for coolant?
//j RR Vogue 4.4 TDV8 - 11
Post #640035 18th Aug 2022 8:39am
JayGee
The expansion tank only needs replacing if it’s been contaminated by oil from a leaking oil cooler. Gearbox and diff fluid does not need access from the front of the engine. Not sure about the EGT sensors. 2012 TDV8 Vogue (L322)
Post #640037 18th Aug 2022 9:06am
jackie-o
Netherlands
Appreciate all the replies. My question was more intended with regards to the front of the engine already being out, if there are any obvious things to do - belts and tensioners being one of them. RR Vogue 4.4 TDV8 - 11
Post #640038 18th Aug 2022 9:30am
dingg1
Water pump is relatively cheap, I'd do it when access is easy.
Post #640039 18th Aug 2022 9:32am
kevinp
Just done all my pulleys and water pump as a precaution. I used Genuine items only though. Had a pattern part sent by mistake and it had more play in it than the one I was replacing.
Post #640046 18th Aug 2022 10:59am
