![]() | Home > Technical (L322) > Reduced performance DPF filter full. |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
I'm talking about inlet manifolds not plenum as per Gary's comment |
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3401
That joint is always loose and can't be tightened as the elbow is rigid plastic. If there is a leak from the interior sealing lip you will see oily gunk around the elbow. 2012 TDV8 Vogue (L322) |
I replaced the whole thing on mine as part of my preventative maintenance program. Old one was a bit sooty.
| garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1494
This is well known for failing - a poor design in my opinion. Inside the plastic pipe is a double lipped rubber seal, which isn't really substantial enough. Over time this collapses in places and leads to intake leaks. Here's a photo with some sections collapsed highlighted:
There's 2 options: 1 - buy the replacement part. It's £170 and permanently solves the issue. Takes 5 minutes to fit. 2 - buy some gas specification PTFE tape (about 80p) from Screwfix/Toolstation, wrap it around the throttle body then re-fit the pipe. This is what I have done (for now) and 1,500 miles later, is working fine. I can't say how long it will last obviously but, a good and cheap interim fix / diagnostic before splashing out £170.
| scuddriver Member Since: 12 Feb 2015 Location: Dunbar Posts: 140
That is most helpful - thank you.
it just flips out with a screwdriver but hold it as it can spring out and into some unreachable crevice in the engine.....
| SETDV8 Member Since: 30 Apr 2022 Location: Kent Posts: 20
Thought I'd post an update.
I keep getting the "restricted performance" warning which occurred again yesterday but with no "limp home" mode. Thid usually clears when the engine is stopped for a while and restarted.
I had the map sensor fault once when I removed it for cleaning and didn’t plug in the connector properly so check that. MAP sensors are not expensive so maybe just change it. 2012 TDV8 Vogue (L322) |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3886
You should try cleaning the MAPT (manifold absolute pressure and temperature ) sensor.
Mine was totally blocked with soot and oil paste but still kind of worked so not sure this would throw a code. Cleaning it IME just gives you a crisper throttle response as it can react more quickly the pressure variations. Should be cleaned every 6 months or thereabouts. 2012 TDV8 Vogue (L322) |
thanks Guys,
That looks clean - this is when it's bad (but still not throwing a code).
| All times are GMT |
