![]() | Home > In Car Electronics (L322) > L322 2007 Android Headunit Options |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2271 ![]() ![]() ![]() |
Yea the only wire cutting you’d need to do would be to the speakers if you were bypassing the dsp amp Current stable:
tymh Member Since: 21 Apr 2014 Location: Garstang Posts: 312 ![]() ![]() ![]() |
I’ve just installed a Navtool box in my L322 and it’s amazing. All fits in the back by the sat nav so n messing about with the dash. Retails access to all factory things like 4x4 and radio etc but adds CarPlay and Android Auto. Takes about half an hour to fit and the hardest part is getting the aux cable through from the back of the car.
Googs Member Since: 19 May 2022 Location: Tassie Posts: 159 ![]() ![]() |
I have one of those nav's but without an amp it is useless, if i can find a DSP Amp i could connect and do much the same.
No. It is literally a CarPlay/android auto unit Tym
You can use the countless apps on your phone to listen to whatever station takes your fancy. Tym
Rjh112 Member Since: 28 May 2022 Posts: 38 ![]() ![]() |
My icebox audio unit will be available if anyone is interested in making me an offer, brand new in box never fitted, the l322 is going shortly to be replaced with a BMW X6M. Give me a DM/PM, mods if this needs deleted I understand |
mdis89 Member Since: 16 May 2022 Location: West Yorkshire Posts: 58 ![]() ![]() |
Ah gutted that you never got to install the unit!
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 433 ![]() ![]() ![]() |
Morning gents.
The icebox one I had linked to, there's no extra long wires to fit, and as far as I can see all the original amp, steering wheel controls etc all work fine.
Ah perfect thanks.
Ah I've not used the gap tool before, if it works let me know!
i noticed in the post
am going to pull the trigger on this one
i was wondering, am about to install the sucker, i plugged the fibre optic to the one that came behind the old head unit and the power cable to the one behind the glove box. but ive got no sound or steering controls. am guessing the fibre optic loop is broken. did you use the loop back cables anywhere? cheers Its actually a sport ![]() Not anymore, 4.4 TDV8 now ![]() |
