![]() | Home > Maintenance & Mods (L322) > Oil removal 4.4L TDV8 |
| Epson Green Member Since: 20 Mar 2021 Location: Sutton Coldfield Posts: 114
Great thread and very helpful as I need to do a full service on mMy newly acquired 2012 Westminster TDV8.
| garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1494
I'd avoid cheap unbranded pumps - my experience is that the vacuum quickly fails. Not experience of this pump but of two different types I've purchased before.
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3397
You can also use an electric pump to extract the oil and someone had a post about this a while back as it was quite a bit cheaper. 2012 TDV8 Vogue (L322) |
| Fla Member Since: 26 Nov 2023 Location: South west Posts: 194
Hi guys
It's Petronas 5000 FJ 5W-30 for the 4.4 TDV8 (quite cheap as a 10L kit from Opie Oils - there's usually also a discount code).
Thanks for the info Gary
Using the Draper tool is really easy. You can crack on with changing the oil filter and any other service parts whilst it's draining.
| drphilgarner Member Since: 20 Sep 2022 Location: Lancaster Posts: 32
I used an electric 'Ultimate Speed' pump I bought from LIDL a few years ago. Worked fine and got plenty of oil out. 2011 4.4 TDV8 Vogue |
I tried the Sealey 12V one and it was useless. Not enough power to suck oil out of an engine. 2015 Range Rover Autobiography 4.4 SDV8 |
| fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1561
I use one of the 12V oil extractor pumps off ebay. Has plenty of suction and has done the job perfectly well each time. I normally connect a battery charger to the +VE and ground posts in the engine bay, and then the pump's croc clips onto the same posts. Seems to ensure the best power for the pump. I pump the old oil out into an old 25l oil canister on the ground.
| ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 284
A question on this that has been troubling me (why I think about these things I do not know), I see that there are mostly 9L extraction pumps that are a reasonable price (I am not opposed to buying the 10L Draper one mentioned in the post) but I was just wondering how people handle the pump getting full?
| Shaun_ Member Since: 02 Feb 2017 Location: New Forest Posts: 92
I use a 30l camping water container to decant it into, so only one-third the number of trips to the local tip for disposal. |
Thanks Shaun, that is a good idea. |
You can disconnect the extraction tube once 9L has been removed (if you have a 9L pump, you can then empty and do the next bit. This is a bit of a faff though, so it"s probably best forking out for the 10L). But otherwise just keep a spare empty 5L washer fluid container for waste oil. By the time you've done 3 or 4 oil changes, on the next one you need only buy 5 litres.
| All times are GMT |
