![]() | Home > Maintenance & Mods (L322) > E-Diff |
They replaced the pan and not just the oil. The pan was leaking. 2012 TDV8 Vogue (L322) |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194 ![]() ![]() ![]() |
What? Are they put old oil back in gearbox?
beemer5711 Member Since: 01 Aug 2022 Location: Wales Posts: 72 ![]() ![]() |
You’re supposed to replace the pan and the oil as the pan houses the filter. |
Oh I see. Yeah I’ve read that a flush can cause more problems than it’s worth. |
Flush I mean change whole oli, not flush with some special washing liquid. Just get dirty oil off from the system compleatly and replace with new one.
I'm happy with a standard drain and fill. It changes enough oil to prolong the life of the transmission which has a very good reliability record and will probably outlast every other component on these cars. 2012 TDV8 Vogue (L322) |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8645 ![]() ![]() ![]() |
And for comparison mine does have one fitted....
__________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 924 ![]() ![]() ![]() |
I don't have e-diff on MY11
Anyone know exactly with what conditions locks activating? How much wheel should spin before lock activate? Other conditions?
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7930 ![]() ![]() ![]() |
You should see it activating in normal mode on the other dash screen, 4x4 info.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2692 ![]() ![]() |
The only way to really know when it is being used is to graph live values for it as there is a threshold below which the indicator light stays green. My son graphed his D4's e-diff which showed that it had significant pre-loading for take-off in a straight line yet the indicator stayed green. |
Changed the diffs and transfer case oil today.
Thank you. How did you get the digital speed in the speedo please? |
Move the terrain response to rock crawl, at least I think that was the one… display changes automatically.
