![]() | Home > Maintenance & Mods (L322) > E-Diff |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3385 ![]() ![]() ![]() |
They replaced the pan and not just the oil. The pan was leaking. 2012 TDV8 Vogue (L322) |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194 ![]() ![]() ![]() |
What? Are they put old oil back in gearbox?
beemer5711 Member Since: 01 Aug 2022 Location: Wales Posts: 72 ![]() ![]() |
You’re supposed to replace the pan and the oil as the pan houses the filter. |
Oh I see. Yeah I’ve read that a flush can cause more problems than it’s worth. |
Flush I mean change whole oli, not flush with some special washing liquid. Just get dirty oil off from the system compleatly and replace with new one.
I'm happy with a standard drain and fill. It changes enough oil to prolong the life of the transmission which has a very good reliability record and will probably outlast every other component on these cars. 2012 TDV8 Vogue (L322) |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
And for comparison mine does have one fitted....
__________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior -Click here for Thread- 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1019 ![]() ![]() ![]() |
I don't have e-diff on MY11
Anyone know exactly with what conditions locks activating? How much wheel should spin before lock activate? Other conditions?
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
You should see it activating in normal mode on the other dash screen, 4x4 info.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2767 ![]() ![]() |
The only way to really know when it is being used is to graph live values for it as there is a threshold below which the indicator light stays green. My son graphed his D4's e-diff which showed that it had significant pre-loading for take-off in a straight line yet the indicator stayed green. |
Changed the diffs and transfer case oil today.
Thank you. How did you get the digital speed in the speedo please? |
Move the terrain response to rock crawl, at least I think that was the one… display changes automatically.
