![]() | Home > Technical (L322) > Reduced performance DPF filter full. |
| garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1494
Maltings are a Land Rover dealer and have them back in stock:
| SETDV8 Member Since: 30 Apr 2022 Location: Kent Posts: 20
Thanks for the info Gary.
Maybe they were looking at the old part number?
I think the fella I spoke to might well have done. I've just tried calling them back but he must be busy. I'll try again shortly. |
https://www.ebay.co.uk/itm/272916567335?ch...ArEALw_wcB 2015 Range Rover Autobiography 4.4 SDV8 |
That's not the part Gary. think that's the plenum chamber. The part I need is the nearside inlet manifold. |
| jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194
SETDV8, how clean/dirty was your old inlet manifold inside?
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3284
here are the part numbers for my recent nearside inlet Manifold replacement (with an updated part for the manifold)
The part arrived, out of the blue, last Tuesday. Got the car back on Friday and all is well.
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3397
| hawkeye651 Member Since: 21 Oct 2019 Location: Melksham Posts: 23
Thanks for the advice Gary. DPF Full light on the dash. Checked the Gap IID Tool code - D2459-65 Diesel Particulate filter regeneration frequency - algorithm based failure - signal has too few transitions/events. Cleaned out the MAP sensor which was very crusty - hence code above. Checked at the hoses which were fine. Put in a shot of DPF cleaner into the tank. Ran the car for 20 mins at ~2500 rpm. Light cleared on dash and on IID Tool 2012 L322 4.4 TDV8 - Current 2012 AM Rapide - Current 2009 Discovery - Gone |
| All times are GMT |
