![]() | Home > Maintenance & Mods (L405) > Just in time for winter...remote climate retrofit |
marshallc Member Since: 16 Nov 2022 Location: Chicago Posts: 2 ![]() ![]() ![]() |
This thread was fascinating to me being us based, so I had to take a peek at my 2016 3.0tdv6. The hvac valve block/under hood section is the same on the US spec diesel variants; has the Eberspacher logo on the side like the OP's photo; but the small fuel line feeding the heater is absent lol!
Edgey808 Member Since: 17 Apr 2016 Location: U.K. Posts: 51 ![]() ![]() ![]() |
Just completed this so easy, when you know how……. Thank you very much knWatkins for this write up!, its absolute perfect………just need a cold day now to test ![]() ![]()
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782 ![]() ![]() ![]() |
No problem. Glad you found it useful |
Llovatt Member Since: 07 Feb 2023 Location: Gloucester Posts: 1 ![]() ![]() ![]() |
Thanks for this write up. I have added all the bits but I can’t find anyone who can code it! What is the cheapest coding tool I can buy to do it myself? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35858 ![]() ![]() |
rather than spend money on something you might only use once, give this chap a call..
LukeSkywalker12 Member Since: 13 Dec 2023 Location: Nuerburg Posts: 2 ![]() ![]() ![]() |
Hi @ ALL !
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 236 ![]() ![]() |
The LED indicator signals various states and conditions for the timed climate as follows:
Thanks, now I understand the remote control better ! |
5c0tty Member Since: 07 Sep 2015 Location: Long Buckby Posts: 28 ![]() ![]() ![]() |
154JON did you manage to fix the issue with your pump? |
E500 Member Since: 10 Sep 2024 Location: Hertfordshire Posts: 87 ![]() ![]() |
If I already have timed climate can I just plug in a receiver (assuming the wiring is there), pair a remote and off I go? Or do I still need to update the CCF to reflect the receiver being present? |
You will need to update the CCF files still, there is an option for remote
Makes sense, thanks Scott. |
I don't have my original build sheet or order forms or anything but I figured since I already had timed climate, it was worth taking a punt on buying a fob and seeing if it'd pair with the car, before buying a receiver as well. I'd have to buy a fob anyway if I had to retrofit a receiver so nothing to lose...
RRL405Ger Member Since: 11 Feb 2024 Location: Munich Posts: 4 ![]() ![]() |
Hello together,
