![]() | Home > General > What Did You Do In Your Full Fat Today |
WDRR Member Since: 12 Feb 2023 Location: Glasgow Posts: 27 ![]() ![]() ![]() |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 ![]() ![]() ![]() |
Yesterday fitted a replacement silver trim strip to the upper tailgate and replacement rear mudflaps from PowerfulUK as one of the originals was missing (and neither side had been fitted correctly in the first place. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Goldstar Member Since: 04 Dec 2021 Location: Reading Posts: 122 ![]() ![]() |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3308 ![]() ![]() ![]() |
Fitted new steering outer track rod ends after garage told me they couldn't align it properly as there was too much play in the joints. Didn't need a ball joint splitter in the end as a couple of 'taps' with 4lb lump hammer did the job but needed a lot of heat on the threaded section to free the threads. Alignment booked on Monday. 2012 TDV8 Vogue (L322) |
Floopy Member Since: 28 Jan 2023 Location: Devon Posts: 98 ![]() ![]() |
Took the family out for the day.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1812 ![]() ![]() ![]() |
Sailed through its 3rd MOT today with no advisories |
cupples8267 Member Since: 20 Aug 2020 Location: Stg Posts: 70 ![]() ![]() ![]() |
Changed the lower control arms. One side ball joint popped out easily, the other side needed heat with oxy-acetalyne, then the steel insert in the alloy hub came out after much pressure and hammering. I then pressed the steel insert off the old control arm in a 25T press. Then pressed the insert back into the hub, and installed the new control arm. Bloody pain of a job. |
Replaced front left height sensor (thank you @advancedfactors)
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1170 ![]() ![]() ![]() |
Gave her a clean. |
damonky Member Since: 24 Apr 2018 Location: Devon Posts: 19 ![]() ![]() ![]() |
Found and fixed a rattling side intake vent with a glue gun 😂
Treated my FF to its first wash with this:
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 200 ![]() ![]() ![]() |
Quite impressed with myself today. I managed to troubleshoot and fix a fault with my fuel gauge reading incorrectly as a result of a Fuel Sender Fault. This is not uncommon from what I can ascertain and affects Disco 3 & 4, RRS and FFRR. Anyway, long story short, it took about 2 hours to learn by doing, and was free!!
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 422 ![]() ![]() ![]() |
Replaced my rear shocks with the aerosus ones, already had done front.
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
The dreaded MOT day again today......WooHoo...passed |
