![]() | Home > Maintenance & Mods (L322) > Retro fitting Paddle Shift to early L322 |
| daveo Member Since: 21 Oct 2009 Location: london Posts: 2307
nice one matt, i have used a small bit of green plastic from a sweet wrapper to turn it green, spot on, you will be leaving yours white i take it as you have the white led conversion on you dash, should be able to pick up a light feed in the steering wheel it self, i sent a link to simon at powerful uk as he to wants to fit them to is demo car..
| mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737
Heres a video showing the paddle shift system working in my 2003 range rover
hi matt, this has turned out to be quite an easy mod, but like you i dont want to loose my heated steering wheel
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470
You have been busy Matt. How long did it take to strip the center console? Any ideas on how to get the wires through the wheel yet? |
Centre console takes literally about 5 minutes to strip, its very easy because it has been designed very well! Just working on getting the wires through the wheel. Matt |
| letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854
looks a cool little mod... |
cost is very little compared to land rover in fact you cant get paddles on early range rovers from land rover, total cost is the paddles, bit of solder, few lengths of wire and a lot of patience and time thats it. Looking into the slip ring and its starting to look like the wireless option may be the only way, although my plan is to remove the slip ring from the car tomorrow an double check to see if there are any few connections that could be used. Matt |
Couldn't you just drill a hole and use a good length of wire with plenty of slack? Bit like the rally cars use but not dangling around? |
I tried that yesterday and it does seem to work but the wires do get wrapped around the steering column, which im not 100% i want or is safe Matt |
what you going to use the spare button for? Matt |
| BigJ Member Since: 16 Mar 2011 Location: North Yorkshire Posts: 247
You could use one of these onto some kind of track to make a connection. Use the crown tip, not the spear tip.
ow many wires do you need to get through the wheel? |
| pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865
brilliant keep us posted please on how get it through the wheel....just a thought but my range rover is a hse so no heated stearing wheel does that mean i may have spare conectors i could use ? "RANGEISM WILL NOT BE TOLERATED"
yes you will have 2 spare connectors where the heated wheel should be connected you only need 2 connectors one for the up shift one for down shift Matt |
| All times are GMT |
