Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 293 |
Hi guys really have hit a brick wall STILL having smoke and horrible fumes which is ONLY intermittent mainly when car hot but that said did a 300 miles roundtrip recently and nothing no smoke or fumes etc... had 2 garages look at it don't know where its coimg from oil cooler done all good o ring on pipe done at back of oil cooler and I been monitering there's no oil on floor driveway etc! surely this oil wouldn't take 4 weeks to burn away from back of engine doesn't it only smoke as the oil hits the exhaust as this gets hot? Any other ideas what's causing these disgusting fumes and smoke at back of engine. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
16th Mar 2023 12:32pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2662 |
It could still be residual oil from the original leak. 2012 TDV8 Vogue (L322) |
16th Mar 2023 1:50pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 695 |
@jaysta10k - When you had the cooler replaced did you fit a JLR part or a budget part?
16th Mar 2023 3:46pm |
Hi it was aftermarket but area is all clear no leaks from the cooler etc.. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
16th Mar 2023 4:16pm |
Gowsh Member Since: 22 Jul 2022 Location: Notts Posts: 5 |
@jaysta10k
14th Apr 2023 2:12pm |
Hi @gowsh cheers for this info we have replaced the o rings on the turbo feed pipe into the back of oil cooler a few days ago with the Viton o rings the back of pipe etc seemed dry to be fair so it’s a process of elimination but very frustrating as everything pointed towards oil cooler. I will keep an eye on this next week or so and if smell and smoke is still present we will take a look at what you have suggested.
14th Apr 2023 3:55pm |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 648 |
just tightened mine up, as I had a mist of oil under mine as well - let's see if that does cure it - fingers crossed ! |
14th Apr 2023 4:01pm |
Any chance of a picture of which to tighten up please.
15th Apr 2023 3:35pm |
Hi, it's the jubilee clips on the short hoses, there's 4 of them. Feel under the hoses first to see if thers oil there, also if they are original they may be split and tightening won't help. |
15th Apr 2023 8:13pm |
15th Apr 2023 8:16pm |
Hi thanks for this @gowsh thanks for this checked all jubilee clips checked all hoses no oil this is a mystery I think the only way to find out where the hell the intermittent smoke and fumes are coming from is for the car body to come off! We have explored all avenues there is one more thing to check a mechanic said he noticed a small amount of oil around turbo area so possible turbo oil leak maybe causing smoke fumes etc when hot. Any. more info from anybody else would be much appreciated.
21st Apr 2023 10:18am |
Smoggie35 Member Since: 21 Nov 2022 Location: North Yorkshire Posts: 9 |
Right guys. Looking for inspiration on this topic from you Guru’s😜.
22nd May 2023 3:24pm |
Are you sure it's engine oil? I had a gearbox leak on the pan seal 2012 TDV8 Vogue (L322) |
22nd May 2023 3:47pm |
Looks like engine oil. Black in colour. Wouldn’t have thought the gearbox oil would be that colour. Haven’t checked the level as the leak looks like it’s coming further from the from the front as only the first wind deflector/ skid pan has oil on the inner surface.
22nd May 2023 5:05pm |
