Home > Technical (L405) > front knuckle cracking
Page 20 of 51 <123 ... 192021 ... 495051>
Spikey62
United Kingdom 2015 Range Rover Vogue SE SDV8 Santorini Black
stan wrote:
"Yes, your VIN falls within the range. It's from 195780 to 228236.
Kev"
Mine is 235972 from May 2015 and it broke just like the others due to possible overtightening from production which caused cracks and subsequent corrosion.
Strange thing is that RR did a recall in Canada in November last year but in UK zilch!!
https://recalls-rappels.canada.ca/en/alert...land-rover
https://www.check-vehicle-recalls.service....13/recalls
So they are guilty in gross negligence in my case and luckily we were not injured nor did the car suffer other damage - well the strut was finished off too.
Post #665595 31st May 2023 11:14pm
Spikey62
Knuckle bolt tightening
Jon Byrne wrote:
I have examined the failed hub carrier and have compared my customer’s failed part to some of the photographs provided on this forum.
When you look closely at ALL of the photographs of the failed part when the bolted part is visible, if you check the gap of the clamping piece , in all cases that I have seen, the clamp has been over pulled. You can tell this as the gap is visibly reduced. In my opinion the clamp should have a gap of around 0.9 mm, measured with a feeler blade, when the bolt is clamped to 60Nm
On all of the cases documented here, including mine, the gap is visibly reduced. In my case the gap in the failed part measures 0.4- 0.5 mm. There’s a slight difference from top
to bottom of the clamp.
I advise a quick test of the clamp is to measure the gap with a feeler gauge. If it’s less than 0.9mm have the clamp thoroughly inspected for cracks. On a lot of examples I have checked, one side of the clamp will break before the other side lets go.
Hopefully that will save some of you from suffering this catastrophic failure.
Hi Jon. I just checked mine and it is 0.4 to 0.35 mm so clearly overtightened... and this has never been touched since 2015!! Steen
Post #665687 1st Jun 2023 11:37pm
GraemeS
Australia
Overtightened or already cracked causing the gap to close?
Post #665712 2nd Jun 2023 12:11pm
Spikey62
Already broken whilst driving so this is what i could measure after the removal of the old knuckle. when it happened on a slow right turn , there was about a third of the metal still intact. The cracks must have been developing for some time.. luckily we were not travelling at speed.. Steen
Post #665714 2nd Jun 2023 12:23pm
Kot
So looking at the Canada Database
https://wwwapps.tc.gc.ca/Saf-Sec-Sur/7/VRD...rn=2022668
Interesting looking at the units effected its 987 is that just Canada or Worldwide?
and corrective actions state dealer will inspect batch number stamped on casting.
So JLR know how many units are affected, know the batch number, but guess they have no idea what was put on what car? Which is strange since we live in the age of verification etc etc OEM parts! 2018 SE SDV8 4.4 Byron Blue
Post #665722 2nd Jun 2023 1:17pm
GraemeS
Australia
Measuring the gap after a failure would be inconclusive.
Post #665725 2nd Jun 2023 1:34pm
Spikey62
Maybe but it was not removed and is intact so probably quite conclusive but that is not for me to decide.
On the right (failed) unit the numbers on it are as follows:
Cast as part of the unit:
ENPSA (possibly manufacturer?)
3K185
AlSi1MgMn-T6
B
Embossed into the metal: A1
Left side as right except (intact but changed):
3K186
C
Embossed into the metal: B6
Steen
Post #665775 2nd Jun 2023 9:14pm
Dgeczi
Just looking online at problems with the front knuckle yiu guys have experienced
In Jan 2022 I had this happen on the left side when I had to slowly drive up a drop kerb and the loud bang resulted on the wheel practically dislodge itself had to have this fixed privately, Land Rover part and small fortune wasn’t covered under any warranty
Today was driving at around 40mph and had to slow down to pull in and bang felt like a blow out on the right tyre almost lost the control but turns out it’s the right side one that has snapped too
Reading all these problems it is crazy dangerous this we were v lucky today and just want to mention this has happened on both mine so be really careful, it is not just a one side problem
Not sure what to do about it as mine is RR Vogue 2014 plate 90k miles but still shouldn’t do this…
Photos of both incident
Post #665900 4th Jun 2023 8:08pm
Spikey62
Kot wrote:
Just seen this on the RRS forum
https://www.rrsport.co.uk/forum/topic58333.html
REMOVED NO HISTORY. GOT A PAY OUT?? Signed a disclaimer?? Anyones guess..
Steen
Post #665904 4th Jun 2023 8:55pm
Spikey62
Unnecessary quote removed
HI - information received from DVSA recently states that:
Quote: DVSA has investigated a number of similar reports of steering knuckle failure, concluding that a failure of the steering knuckle is a safety concern as defined within the Code of Practice. DVSA has recommended that further action (recall) is taken by the manufacturer, and we are continuing to engage with them on this topic so that a suitable agreement can be reached, and solution introduced.
Unfortunately, whilst this remains ongoing, I am unable to give you any further information. However, please be assured that DVSA are fully committed to reaching a satisfactory outcome.
End quote
So you take to your local Land Rover garage and tell them to call HQ as there is a recall for this part. I just checked the DVSA site and there is nothing live yet but this information has come from DVSA via another claimant and Land Rover is aware of this - they have been told to do something about it finally!!!! The Canada recall for 987 vehicles in January 2023 is another argument that they need to take this seriously... I enclose copy which was kindly offered by a Canadian user in this forum.
Apparently the email account is no longer working and they want communcation via Facebook, Twitter or Instagram - I posted my claim today on Facebook as a post as well as a messager via Messenger but mysteriously it no longer shows on the page.. I wonder why... I can still find the post but no longer visible...
Post #665912 4th Jun 2023 10:30pm
Kot
Steen
Wow what's going on? I couldn't even log on to that site, my password (stored on mac key chain) didn't work. Had to use the forgot password link to get back on??? Someone must have been upset by my post on here?
Can anyone just delete the thread? or just the OP or can only admin creatures delete?? 2018 SE SDV8 4.4 Byron Blue
Post #665941 5th Jun 2023 11:38am
Dgeczi
Spoke with JLR this morning they are not aware of any problems with this issue, i told her to Google this site......
Told her am very lucky to be in one piece and looks like this is a problem that is not a one off (i have had two go on me now left and right)
Wants me to take it to local LR guys to look at but WILL NOT be covered under anything as i have not got extended warranty
More i think about it the angrier i am getting as this is a problem that they are ignoring and chances are has already cost someone's life
Has anyone got a link to DVSA complaints for this kind of thing reading above sounds like this already in motion.
All help appreciated
Post #665943 5th Jun 2023 12:01pm
AnotherMutley
Thought about ringing BBC Watchdog?
If you can get enough people to join you, they'll be interested.
Post #665945 5th Jun 2023 12:16pm
Dan_Veluwe
Netherlands
@Dgeczi
Horrible failures !
EDITED : recovered VIN range from earlier posts. I-pace First Edition Santorini & 2nd car Mazda MX-30 Advantage red/black
PHEV P400e Hybrid Autobiography Loire blue= SOLD
D5 SD4 HSE Lux Corris grey = SOLD
D3 TdV6 HSE Lux Vienna Green =SOLD
P300 F-Type 2018 Ultra Blue = SOLD
25t F-Pace 2020 Loire Blue = SOLD
Post #665958 5th Jun 2023 2:53pm
Dan_Veluwe
Netherlands
@KOT
The post has been removed..
"..The topic or post you requested does not exist.." I-pace First Edition Santorini & 2nd car Mazda MX-30 Advantage red/black
Post #665959 5th Jun 2023 2:55pm
