Home > General > What Did You Do In Your Full Fat Today
Page 364 of 384 <123 ... 363364365 ... 382383384>
mgrover
Wasn't today per say but the latest affair was replacing all the vacuum hoses at front with silicone. While there also doing the vacuum pump gasket and oil pressure sensor.
They really don't leave a lot of space to work on this thing do they. Like if one could remove the fan it would be fine but the coolant pipe going across the top makes it a nightmare. Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #671887 24th Aug 2023 8:18am
Proftinkerpot
Northern Ireland 2012 Range Rover Westminster TDV8 Stornoway Grey
So after almost 8 months of owning my 2012 Westminster, and having covered 6000 trouble free miles - this evening on the drive when I started the enginevi got a gearbox, drive train and restricted performance warning. The gear selector didn't pop up. I switched off the engine got out and locked and unlocked the car. I restarted the engine and still got the restricted performance warning and the dreaded orange engine light on the dash. So it will be a trip to my mechanic next week as I dont have a plug in diagnostic to read and clear the fault code. Hopefully it's something minor like a sensor that can be swapped out easily.
I guess it also means I need to think about getting a code reader.
Post #671956 24th Aug 2023 10:52pm
Kiss My Carbon Footprint
United Kingdom 2011 Range Rover Autobiography TDV8 Orkney Grey
Bought a LR bike carrier from fellow forum member and jolly nice chap belldarr.
He freed up some space in his garage as a result.
And I didn't.
Errm....
Warwick 2011 L322 TDV8 A/b Orkney Grey
2008 Defender 90 XS TDCi Java Black
2002 L322 TD6 Vogue Zambezi Silver (gone but not forgotten)
And one or two bikes - Ok, maybe more than one or two....
Post #672110 27th Aug 2023 8:05pm
landy95
Fitted a new genuine LR brake vacuum pump, this will hopefully eliminate the red arrows exhaust when I boot it as it also acts as a turbo oil lube scavenger pump. Fingers crossed. Also own a 1976 Land Rover 101 3.5 V8.
Previously owned:-
2012 Range Rover Westminster.
1991 Range Rover Vogue 3.9 V8.
Post #672123 27th Aug 2023 10:05pm
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
Fitted a mint pair of rims on the rear and rotated tires (inside out, front / rear).
Fitted UV protection film on the windscreen and covered delamination along the top with a strip of glossy vinyl. Turned out fantastic Thumbs Up
Ordered a few rattle cans of spray paint. Next up: door handles, roof strips, seat valance trims and foundry colored cup holder...And some stone chips on the bonnet.
Post #672361 30th Aug 2023 8:25pm
PeteT80
Replaced both lower tailgate cables.
Post #672640 3rd Sep 2023 8:15pm
hogesar
Having only recently bought her....
Had all 4 manifold hoses replaced with the white-lettering pipes earlier last week.
Today had the iphone to bluetooth adapter delivered and tested.
Should have replacement number plates delivered tomorrow (existing one's look tired and poor).
Also got some paint to tidy up the tow bar which i'll hopefully do one evening this week.
Post #672694 4th Sep 2023 4:39pm
Proftinkerpot
I replaced my left side cable which snapped last week. When I checked the right side it was like new so clearly had been replaced before I bought my Westminster. They seem to go in the same place. I sprayed a little white grease inside the rubber sleeve and the rubber cap ends to try and ward off moisture getting into it.
Post #672702 4th Sep 2023 8:05pm
tj196443
United Kingdom 2010 Range Rover Vogue TDV8 Zermatt Silver
LED interior upgrade
Fitted LED’s to the interior lights, reverse lights and number plate lights. What a difference they make, much brighter.
Post #673104 10th Sep 2023 8:10pm
Gremlin500
Wire brushed and kurust 661’d my rusty steering gear support brackets, and topped up the lanogard under the car, great weekend for it before the dark days arrive!
 V6 Vogue - “Less is More” - less to go wrong!
Post #673110 10th Sep 2023 10:27pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Made mine work by doing 550 mile in one go with one break of getting food, drink and petrol whilst towing this.
Despite the trailer nearly weighing 3ton, the range pulled it with no trouble from Essex to Preston and back
Surprisingly only chewed 3/4 of a tank of petrol on the way back
Happy days I'll take that
Post #673113 11th Sep 2023 7:14am
Seatown
Scotland 2013 Range Rover Vogue SE SDV8 Firenze Red
Fixed a coolant leak as per Fisha's very helpful write up here www.fullfatrr.com/forum/topic66813.html
Post #674231 25th Sep 2023 3:14pm
Sandyt
Just had Bodsy round and did gearbox both diffs and transfer box done on both l322's superb service as ever Thumbs Up Thumbs Up
Post #675439 12th Oct 2023 7:16pm
Huttopia
Towed someone out of one of the fields. They turned around in a field entrance, on a slope and then got stuck. Rather than sit there 2m away from tarmac, they opened the field gate and reversed into the field in the hope of getting a run up. Uphill. On wet grass. In a Ford Focus with 2mm on the front tyres. The lady came running up to the farm in a fluster, whilst the mid 20s son sat in the driver's seat. I've not had a vehicle with a screw in towing eye, and she didn't have a clue, so it took a bit of finding and fitting (reverse thread got me for a moment). Uphill, tight angle to get through the gate and I'm straight onto a lane a right angles, all of 6m from the gate. All a bit awkward but we got there after a fashion.
Obviously they offered me £20. Obviously Laughing
Post #675473 13th Oct 2023 9:55am
colalowe
United Kingdom 2012 Range Rover Autobiography TDV8 Buckingham Blue
Land Rover Experience
My Mrs bought me a Land Rover experience afternoon at the North Yorkshire site.
Had a blast driving a brand new Range Rover around the track, was amazed at just what they can do especially as it was throwing it down and blowing a gale and on road tyres!!
Fantastic day and well worth doing if you can, have learned so much about the Terrain response system and the best way to use the car. Thumbs Up 2012 TDV8 Autobiography Baltic Blue
Previous
2007 BMW M5 E60
Post #676065 21st Oct 2023 5:36pm
