|  | Home > My Range Rover > Back with another Supercharged! A 5.0 this time! |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | On my 4.2 RR I replaced the bearings in the auxiliary idlers. When I pressed them out they were 6203-2RSH which I could source without any problems.
|  22nd Aug 2023 8:49pm |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | The tools to remove the crankshaft pulley arrived today.
|  24th Aug 2023 7:38pm |
| Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2287      | Looking good David yes afraid there is always at least one who thinks every bolt and cap needs to be put on as tight as possible - today my eldest tore the cap off the petrol tank on the outboard because some numbskull had graunched it on so need a new plastic fuel tank.
|  24th Aug 2023 8:01pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | Top job as usual, you'll be cleaning all that up soon I guess...  | ||
|  24th Aug 2023 8:25pm |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | Yup, the vacuum pump is coming off to have a new gasket put behind it whilst it’s in bits.
|  24th Aug 2023 8:50pm |
| Ennoch Member Since: 26 Dec 2015 Location: Scotland Posts: 109  |
 LAX, aside from being a terrible airport, is likely to be some specific automotive spec. Possibly angular, bigger balls or some non-standard size. Do the outside measurements match the stock 6203 dimensions? If you know you're going to replace them anyway then I'd cut one open to see what's in there. If it looks like a normal bearing then I'd replace it with a high quality, high speed one. Apologies if this is teaching you to suck eggs! Have you tried contacting NTN directly to find out what this code is? I've done this before with other things and generally found with a little perseverance and asking nicely you can get a long way in answering obscure questions, even from large, faceless corporations. | ||
|  24th Aug 2023 9:00pm |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | I spoke briefly to bearing boys who reckoned it was a batch code or something similar.
|  24th Aug 2023 9:12pm |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | After doing some shopping around for a starter motor, I found this on eBay:
|  27th Aug 2023 8:52pm |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | Today, as the timing tools had arrived I rotated the engine over and pinned the flywheel using the tool that goes in the position of the crankshaft sensor.
|  27th Aug 2023 9:31pm |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | Everything needed to do the timing chains has now arrived from Duckworth’s.
|  1st Sep 2023 8:06pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | Wow, that's a shed load of bits....
|  1st Sep 2023 9:34pm |
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631    | Those camshaft dephasers are quite bad, I'd like to say it's because of the lack of oil feed - but it could be just as well caused by the chain stretch, which may have been made worse by the lack of oil feed - but only slightly.
|  1st Sep 2023 10:02pm |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | What surprised me is the sprocket that sits on the crankshaft is totally unmarked and looks like new.
|  2nd Sep 2023 9:02am |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | Had a good look at things as I started to plan my rebuild on Saturday and decided that I didn't want to use the original crankshaft sprocket. Although you couldn't feel any marks on it, you could see them when looking at it in daylight.
|  5th Sep 2023 12:06pm |
| Posting Rules
