Home > Technical (L322) > Paddle Shift?
Page 5 of 7 <1234567>
Baben
South Africa 2014 Range Rover Autobiography SDV8 Luxor
AND IT F Censored G WORKS !!
Post #60505 15th Apr 2011 8:03pm
Baben
so 3 easy steps
1) buy paddles from TLO (disco3)
2) buy MSV2+ from BBS
3) plug in paddles
4) enable paddle shift in CCF
5) et voila! enjoy
Post #60507 15th Apr 2011 8:06pm
daveo
hi Colin, just wanted to ask a few questions,
the gate way module thats needed for the ibus to talk with the can bus needs reprogramming, does it have to be a new unit or can a used one work.
do you need any thing more in order to fit the module in to the system
has the module got to be programmed in the car.
i think i have now found one, he wants good money and have been thinking it may be better to add the rest and go for a new one.
thanks dave V8 facelift Range Rover Autobiography 22" wheels.
Post #60508 15th Apr 2011 8:10pm
daveo
Baben ... the paddles what do they fix to,is it the steering wheel itself. just had my wheel re-trimmed in two tone , do you have some photos
what year is your car before i get any more excited V8 facelift Range Rover Autobiography 22" wheels.
Post #60509 15th Apr 2011 8:18pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
if he has said he has edited his CCF file he must have a post 05 (touch screen model) as pre 05 vehicles didnt have CCF files, thats the whole point of the gateway module.
@BBS - if we fitted a gateway module into our pre touch screen range rovers without the rest of touch screen infotainment system could we install the paddles?
Matt
Post #60517 15th Apr 2011 8:54pm
Baben
yes it is a 2010 5.0 s/c
the paddles are the same as the 2011 4.4 TDV8 - they are in integral part of the steering wheel, and can be retrofitted to the 2010 steering wheel by simply snapping out the rear of the top panel.
I tried to take pics but its dark and all you see are the lights of the dashboard. i will take pics tomorrow in the sunlight
Post #60521 15th Apr 2011 9:03pm
daveo
matt if you use the gate way module you can start to use things like the venture cam, it allows our cars to talk to the canbus.. Rolling Eyes he just said his car is a 2010.
i thought the same the gate way was for the pre touch screen.
so is this mod for the pre touch screen or for the later models V8 facelift Range Rover Autobiography 22" wheels.
Post #60525 15th Apr 2011 9:14pm
mattstevenson2005
hi dave, the gateway module was only used in a very limited run of vehicles from when they fitted the first touch screen system until they redesigned the interior, from then on they combined the gateway module into the instrument cluster. If you do fit a gateway module, how will you be able to use the venture cam? you need the touch screen infotainment system for venture cam to work as the BMW infotainment system does not support venture cam.
Post #60528 15th Apr 2011 9:27pm
daveo
hi matt your right, they only fitted them to the 2005 cars that had the first touch screens and as they started updating the electrics, they are very hard to find... i have had several conversation with bbs spy who prompted me to the gate way module after me telling him i wanted to use the venture cam, also he was working on a module that would allow you to use the 2010 switches on the i bus system.. he is very technical and i have to read his post a few times before it goes in... V8 facelift Range Rover Autobiography 22" wheels.
Post #60535 15th Apr 2011 10:05pm
BBS SPY
Cyprus 2003 Range Rover HSE 4.4 V8 Java Black
Congratulations Baben
You may have well discovered the 4x4 info enabling, by simple CCF editing, equivalent for the 2010 on FFRR Thumbs Up
As you know, i was concerned that you might need to re flash your other ECU's as well, because your ECU's might not automatically support Paddle shifting, especially since this was not a manufacturer option on your model.
But it seems they do and i thank you for being the Guinea Pig that discovered this Wink
Powerful stuff this CCF editing, and pretty stunning to think no one had even heard of it until i first mentioned it. Rolling with laughter
Matt and Dave
This mod has no applicability to anything pre 2010
For clarification, i have two separate and un related projects currently on hold.
The first is the fitment of 05 to 09 infotainment equipment to pre 05 FFRR vehicles which uses the Gateway ECU fitted only in 05 Vehicles
The second is the fitment to a Discovery 3 or pre 2010 Sport with the steering wheel fitted to Disco 4 or 2010 on sport models, including paddle shift capability.
This second project may well migrate into providing any pre 2010 FFRR owner with the ability to fit a 2010 steering wheel to their vehicle, including paddle shift capability.
But i really can't make any promises Whistle 2003 4.4 HSE
Post #60652 16th Apr 2011 8:03pm
Baben
some video evidence
apologies about the quality, iphone 3 doesn't exactly make it as a broadcast tool
&feature=youtube_gdata_player
but you can hopefully make out the "supercharged" label on the tachometer, and the D2, D3 etc gear annunciator underneath, and see the paddles changing gears
Post #60874 18th Apr 2011 5:43pm
mattstevenson2005
thats great but bit of a short video
Post #60877 18th Apr 2011 6:50pm
Baben
well the s/c makes most roads feel short Smile
will make a proper video soon. i am just quite chuffed that my 12-year-old hooked me up to youtube
Post #60884 18th Apr 2011 7:46pm
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
So at the moment the only solution for pre 2010 owners is to do what Matt did. Using radio controls in the wheel to control the gear changing. Shame it needs a bit of soldering and modding, but does not look too complicated.
Post #67274 6th Jun 2011 6:24pm
daveo
its not a hard job if you can use a soldering iron V8 facelift Range Rover Autobiography 22" wheels.
Post #67334 6th Jun 2011 8:46pm
