Home > Maintenance & Mods (L405) > Retrofit Deployable towbar - how to
Page 4 of 5 <12345>
Frans
Netherlands 2014 Range Rover SDV6 Baltic Blue
Can you use the intern of an Range Rover Sport Tow bar for use at the vogue ?
So the electric motor and the swivel
Post #682143 8th Jan 2024 2:50pm
Stan1971
United Kingdom 2016 Range Rover Autobiography SDV8 Carpathian Grey
Has anyone managed to get a module working that has been purchased from eBay? I’ve been told by a LR specialist that the module is coded to the original vehicle and can’t be changed, therefore useless. Has he got mixed up?
Post #683854 25th Jan 2024 12:18pm
Ryanmt
United Kingdom 2017 Range Rover Autobiography SDV6 Santorini Black
I put a 2nd hand module in my 2017 and programmed it no problem.
I suspect the motor/swivel is the same but I haven't inspected it that closely.
Post #683855 25th Jan 2024 12:20pm
Stan1971
Thanks Ryan Smile
Post #683856 25th Jan 2024 12:21pm
iainvr4
2004 Range Rover Vogue Td6 Java Black
Ryanmt wrote:
Following on for part C + D
Spoke to the dealer today and you still can't purchase them separately, the same part is used on the aftermarket westfalia towbars, I called them too and they cant sell that part either. Rolling Eyes
People have fitted them without the bracket but it means you end up with 2 less connecting bolts between the towbar and the chassis. I'm probably going to fabricate some - if anyone has one handy or happens to be lying under their range rover any time soon would you be able to let me know the thickness of them?
Hope you are well. I know it was a few years ago but did you ever get the full parts list for the 2017 L405? I am looking to get one fitted to mine.
Thanks
Post #714994 27th Mar 2025 7:36pm
Ryanmt
The full parts lists for each year are in this thread. I fitted mine a good while back and it's been working fine ever since.
A guy on here started manufacturing the brackets Landover don't sell outside of the full kit if you can't find them used.
Which bit are you stuck with?
Post #714996 27th Mar 2025 8:24pm
iainvr4
Thanks for the reply, the list for the 2017 comes up with switches and the loom but not the module. So struggling to find the module part number. I have got a loom and the switch I think. I’ve not looked at the bracket yet.
Post #714998 27th Mar 2025 9:16pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
There's no specific module for 2017 on, I believe it uses a module that is shared between the deployable side steps and towbar. Upto 2017 MY had a specific module that installed into the right hand boot area. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #715000 27th Mar 2025 9:23pm
iainvr4
There seems to be loads of modules. Any idea what is the part number?
Post #715003 27th Mar 2025 9:30pm
4RRS
Seems to be VPLGT0204 FROM VINHA000001.
You can check here: -
https://parts.jaguarlandroverclassic.com/p...and-rover/ L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #715004 27th Mar 2025 9:37pm
Ryanmt
Do you have (or plan) to fit the deployable side steps?
Post #715007 27th Mar 2025 9:48pm
iainvr4
No don’t plan on the steps
Post #715009 27th Mar 2025 9:54pm
Ryanmt
https://www.ebay.co.uk/itm/276970260543?mk...media=COPY
This will get you up and running then. You might need the holder bracket, in fact I would take a nosy in your boot before buying it anyway just incase you have a module already. Wfedt is what you need on the module
Post #715010 27th Mar 2025 9:56pm
iainvr4
Brilliant, thanks where is it in the boot? Also does it need coded?
Post #715012 27th Mar 2025 10:00pm
Ryanmt
The left side in the spare wheel well area. The installation instructions for the tow bar has some good diagrams
The car needs coding with the module yeah. I'm sometimes over in Edinburgh if you get stuck on that one but anyone with pathfinder can do it (Inc the dealer!)
Post #715013 27th Mar 2025 10:02pm
Page 4 of 5 <12345>
