![]() | Home > General > What Did You Do In Your Full Fat Today |
| AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 705
Hi,
| rainking Member Since: 14 Jan 2019 Location: Buckingham Posts: 75
Today was/is MOT day for mine.... passed without issue |
| Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 408
Drove past here on Sunday after a weekend away in the Cotswolds, so rude not to take a snap... no sign of Jeremy or the L322 |
3 months now after pulling the fuse for auto wipers, no problems at all, much less frustrated and change has proved uber reliable using adjustable intermittant wipersI just drive with lights on all the time "Auto", they still turn off with the ignition, so all good.
| Dutchgit Member Since: 17 Sep 2023 Location: Emmerich am Rhein Posts: 189
Came back from Switzerland (Haute Nendaz) yesterday after a week of skiing.
Replaced the two BS611 oil rings due to leak this morning, old ones were hard and crusty, 1 broke removing it, hopefully all good now.
| Rex the RR Member Since: 15 Nov 2019 Location: Perthshire Posts: 44
Exchanged my 2011 4.4 tdv8 vse of 10 good years for a 2021 p525 AB. Only doing short journeys now so back to a petrol! |
| MC-RR Member Since: 26 Jan 2022 Location: Monte Carlo Posts: 30
Hello to all.
| JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 299
MOT time, passed with a couple of minor advisories that I’ll sort out when it gets a bit warmer. I guess I’ll be keeping it for another year at least then |
| RobErica Member Since: 16 Nov 2023 Location: Loosbroek Posts: 39
Finally gave myself the time to check the little rumble that i felt for a while now. Had my suspect, and now i have certainty.
Replaced rear anti roll bar rubbers, took the opportunity to mist spray entire rear subrame & chassis with Nitomors & then Dintrol.
Found some paint bubbling under the rear tailgate lid, not too bad so I think I will try some stuff to hold it at bay for a couple of years. Had a good look at the wheel arches when I found it, but they look ok
| ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 150
Did 15 miles of off road driving in Mid Wales. And pulled two fallen trees out of the way.
| cupples8267 Member Since: 20 Aug 2020 Location: Stg Posts: 72
Changed the ARB bushes, easy job on the drive with some 3t vehicle ramps. The old ones were fitted by the dealer 18months or 10k miles ago. They didn't look worn but the ARB was fairly easy to move, and once the brackets were off the sub frame they were definitely loose. I used genuine bushes with a receipt from the dealer so that if the ARB seals go they can't say it is due to me using non-genuine parts. I'd be interested to hear what aftermarket bushes others use. |
