Home > General > What Did You Do In Your Full Fat Today
Page 370 of 384 <123 ... 369370371 ... 382383384>
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Did a day's marshalling on a vintage trial, having to drive over soaking wet grass is certainly entertaining, down hill is the only option, I'm sure the grass will recover in time, the old beast will now require a wash, badly.
Post #688303 17th Mar 2024 8:56pm
minim
Norway 2013 Range Rover TDV6 Santorini Black
Did an oil change after completing the wrap removal. Finally back to santorini black Smile
Post #688310 17th Mar 2024 9:25pm
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
Just drove it 100 miles… with a caravan on. Not the first time I’ve towed the caravan with the RR, but not towed with it that far before, or on motorways before.
The SDV8 and auto box is so, so much nicer than the 2.7 TDV6 and manual box of the Discovery 3 that we also own. Achieved about 23 mpg towing with both cars, so not much difference. The only area where the Disco wins is for low speed manoeuvring, especially on slopes, where the control of the manual and clutch gives finer control.
Post #688315 17th Mar 2024 10:01pm
hmallett
Fitted a genuine LR luggage divider/dog guard today. Now the dogs can make a mess of only the boot, and not climb over onto the back seats, then into my wife's lap. Censored
Post #688828 23rd Mar 2024 8:42pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Bought Fattyetta some new wheel locks, couldn't justify stumping up the £200 or so for the stainless steel hand crafted ones, but got these chromed / zinc plated ones with a so-called anti rust guarantee, time will tell.
Look very nice, will not fit them to the car until the new wheels come though.
Andy
 Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #689194 28th Mar 2024 9:50am
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
Visited my parents 45 miles down the m20. Car is fairly new to me so impressed with this:
Post #689227 28th Mar 2024 3:02pm
Ajmngn
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Fitted JXB Performance prop shaft centre bearing carrier. Rubbers on existing carrier were shot, this will help. The bearing is also shot but that’s a job for another day.
 Andy
2010 4.4TDV8 Vogue SE in Santorini Black with Ivory interior
2017 Audi SQ5 3.0 V6T Quattro in Volcano Red
2001 Audi Allroad 2.5 TDI manual with low-range in Highland Green (Currently SORN whilst undergoing some serious restoration!)
Post #689499 31st Mar 2024 1:31pm
PDC
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
I spent the day yesterday changing all the fluids. Rear & front differentials, transfer box, engine, and power steering. I will do the coolant flush next weekend. luckily the rain held off for the day. Very Happy 2010 RR Autobiography 5.0 SC
2020 F-Pace SVR 5.0 SC
2018 RRS HSE Dynamic 3.0
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #689545 31st Mar 2024 8:23pm
AndyRoo
Removed all the arch liners and side sill trims to check for rust now the winter's over, 1st chance since getting the car.
Nothing in the front at all, no staining even, waxoyled using clear version so can see if anything appreas in the future.
Did the rears, small amount of staining and some minor surface corrosion, wire brushed off and converted using Nitromors inhibitor, followed by Tetraseal and Waxoyl clear.
Waxoyled all the sills and underbody.
Fitted Freelander trim on the rear arch lips previously, removed for visual check some signs of surface rust, so treated with Nitromors and Tetroseal, will not be refitting them as this was hidden from view. Plan to remove the rear arch liners at least once per year going forwards.
Post #689622 1st Apr 2024 5:09pm
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Picked car up from detailers then swapped over the steering wheels. Got my nice piano black overfinch steering wheel on my new 2011 overfinch. Now that makes me happy.
Post #689624 1st Apr 2024 5:15pm
PeteT80
The infamous P040D-00 temperature sensor, plenty of soaking with penetrating fluid of your choice is the key.
Post #690992 20th Apr 2024 7:33pm
AndyRoo
Fed up with umbrellas rolling around in the boot where they can't be reached, bought a neat matching pair of storm resistant golfing umbrellas and mounted on the rear shelf using black plastic coated Terry's
Much better and can just reach over for them now and don't rattle.
Post #691124 22nd Apr 2024 9:58pm
Squirrel
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Galway Green
Had it recovered for the second time in a week. Evil or Very Mad
Post #691193 24th Apr 2024 11:54am
darren3005
United Kingdom 2015 Range Rover Vogue TDV6 Santorini Black
Well Yesterday really but I was so happy I forgot to post it.
MOT whoop whoop, all passed with one advisory, which totally contradicted the technicians at MD Taunton. when the examiner parked it outside the test centre I knew it had passed. Very Happy
Post #691582 30th Apr 2024 8:48am
mcspreader
United Kingdom 2010 Range Rover Vogue SE TDV8 Zermatt Silver
I've eventually got round to having a go at the Parking Sensor - Short to battery LED issue. After much deliberation I got hold of a 12v orange LED and spliced it into the relevant wire coming out of the parking sensor module and grounded it to the module attachment stud. Sensors now work again. No way I'm ever going looking for the dodgy bit in the loom or replacing the HVAC control module which shares the parking sensor switch and is £968 from JLR, if it's ever back in stock. Cost of bodge £2 for LED plus a Wago I had in stock and a crimp on ground eye from the same. I'll just put up with the lack of indication at the switch (which still shows as operative in IID live values).
Also ordered up some Viton o-rings for the turbo oil feed pipe which I suspect to be the culprit in sharting oil all over the place and smelling like the car has caught fire. I had to buy quite a lot so may make some of the spares available to the community, assuming they are the right size. Rolling Eyes 2011c Vogue SE 4.4 Oil Burner
1991 Hilux 2.4d MkIII. Sadly goone due to space and time.
2008 Skoda Octavia Scout
2000 TVR Tuscan 4.0
Loads of crap. Gone
Post #691838 3rd May 2024 5:19pm
