![]() | Home > General > What Did You Do In Your Full Fat Today |
minim Member Since: 15 Mar 2024 Location: Bergen Posts: 36 ![]() ![]() ![]() |
Did an oil change after completing the wrap removal. Finally back to santorini black |
hmallett Member Since: 21 Jan 2024 Location: Mid-Wales Posts: 122 ![]() ![]() ![]() |
Just drove it 100 miles… with a caravan on. Not the first time I’ve towed the caravan with the RR, but not towed with it that far before, or on motorways before.
Fitted a genuine LR luggage divider/dog guard today. Now the dogs can make a mess of only the boot, and not climb over onto the back seats, then into my wife's lap. |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 673 ![]() ![]() ![]() |
Bought Fattyetta some new wheel locks, couldn't justify stumping up the £200 or so for the stainless steel hand crafted ones, but got these chromed / zinc plated ones with a so-called anti rust guarantee, time will tell.
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 368 ![]() ![]() ![]() |
Visited my parents 45 miles down the m20. Car is fairly new to me so impressed with this:
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 196 ![]() ![]() ![]() |
Fitted JXB Performance prop shaft centre bearing carrier. Rubbers on existing carrier were shot, this will help. The bearing is also shot but that’s a job for another day.
PDC Member Since: 02 Oct 2018 Location: Warwickshire Posts: 86 ![]() ![]() ![]() |
I spent the day yesterday changing all the fluids. Rear & front differentials, transfer box, engine, and power steering. I will do the coolant flush next weekend. luckily the rain held off for the day. |
Removed all the arch liners and side sill trims to check for rust now the winter's over, 1st chance since getting the car.
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 785 ![]() ![]() ![]() |
Picked car up from detailers then swapped over the steering wheels. Got my nice piano black overfinch steering wheel on my new 2011 overfinch. Now that makes me happy. |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 232 ![]() ![]() ![]() |
The infamous P040D-00 temperature sensor, plenty of soaking with penetrating fluid of your choice is the key.
Fed up with umbrellas rolling around in the boot where they can't be reached, bought a neat matching pair of storm resistant golfing umbrellas and mounted on the rear shelf using black plastic coated Terry's
Squirrel Member Since: 15 May 2012 Location: Reading Posts: 212 ![]() ![]() ![]() |
Had it recovered for the second time in a week. |
darren3005 Member Since: 01 Nov 2023 Location: Somerset Posts: 66 ![]() ![]() ![]() |
Well Yesterday really but I was so happy I forgot to post it.
mcspreader Member Since: 28 Jan 2017 Location: cornwall Posts: 57 ![]() ![]() ![]() |
I've eventually got round to having a go at the Parking Sensor - Short to battery LED issue. After much deliberation I got hold of a 12v orange LED and spliced it into the relevant wire coming out of the parking sensor module and grounded it to the module attachment stud. Sensors now work again. No way I'm ever going looking for the dodgy bit in the loom or replacing the HVAC control module which shares the parking sensor switch and is £968 from JLR, if it's ever back in stock. Cost of bodge £2 for LED plus a Wago I had in stock and a crimp on ground eye from the same. I'll just put up with the lack of indication at the switch (which still shows as operative in IID live values).
