Home > Technical (L322) > Removing CVD dampers and replacing for standard
Page 5 of 6 <123456>
GraemeS
Australia
coopss wrote:
Interesting mate - can this be done safely with a GAP tool?
I've updated several modules with the Gap tool.
Post #606265 12th Sep 2021 11:02am
jeremy156
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
LandyManSam wrote:
I'm due to do the same mod this weekend (I have all 4 new dampers ready to go on) but I need to know what CCF settings you changed exactly with the IID tool in order to get everything working nicely. Any help much appreciated!
Sam
Sam, did you go ahead with this in the end? Was expecting to find a video about it... Smile
Post #706794 13th Dec 2024 6:40pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
I'm getting a bit fed up of the harsh ride on my 2012 Westie, I feel every bump in the road, and it's quite bumpy over speedbumps whereas my 2006 car was fairly floaty, maybe too much so.
I've nothing to compare it with honestly, it's a huge expense to go to to replace all 4 shocks with new active ones, and not much cheaper to get non active ones.
How can I tell what my ride is supposed to be like as mine feels overly harsh ?
& can I disable the CVT temporarily so that it reverts to comfort just to check it ?
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #711214 6th Feb 2025 12:33pm
kevinp
If you want a floaty front end then fit some Dunlop struts and bags.
Had to change mine because of a leak in one air bag.
Is it possible that old shocks have 'stiction' due to wear causing the harsher ride?
Post #711216 6th Feb 2025 12:46pm
Dtech
England 2011 Range Rover Vogue 4.4 V8 Santorini Black
I feel exactly the same as Andy roo. The ride quality on my 2011 4.4 with 95k on the clock is horrendous compared to my previous 2005 l322. I am also looking into the possibility of replacing my shocks with standard old school ones. The other problem is the ride quality issue is unpredictable,occasionally the ride can be fine then the next journey it’s back to the bone shaker ride again.
Post #711253 6th Feb 2025 7:35pm
GraemeS
Australia
The shocks will be at their firmest if the sytem is disabled, which is easy to do by unplugging a front shock's electrical connector. If the ride isn't much different on other than very smooth surfaces then unless the CVD system has a hardware fault causing incorrect operation of the valves, the shocks are worn-out and unable to smooth the ride. Note that air-springs don't provide any damping, unlike steel springs which do, so if a shock isn't damping on even the smallest of shaft movements then the ride will be harsh.
I replaced all shocks several years ago with Bilsteins when it became obvious that the originals were worn-out, after which the good ride was restored. However I was dissapointed that Bilstein had fitted Dunlop air-springs rather than Continentals, one of which failed 2 years later on an internal fold where it couldn't possibly have been damaged externally.
Post #711264 6th Feb 2025 8:52pm
TorontoDee
Canada 2012 Range Rover Westminster 5.0 SC V8 Santorini Black
Do just the front shocks get swapped out or do the air springs also have to be replaced with them at the same time 2012 Supercharged L322
Post #711275 6th Feb 2025 10:13pm
AndyRoo
Hi, I can't help feeling that I'm following the route of Sam of Sam's Motor and Machine, I've been going through his videos recently and almost every step is Deja Vu, that's just like mine etc..
I've tried the old DSC Off and Sand Mode with DSC off bit, but I've not noticed any difference.
I've pretty much resigned myself to the fact that the whole lot are shot and I'm in the hole for £2k worth of parts. Car's only done 80k, but it's still 12 years old now. I could carry on driving it, it's perfectly useable.
I'm going to work my way up as he did with the cheapest parts first, do the levelling calibration, then the height sensors, then the rear shocks, I'm going standard CVD not Bilstein, then I guess I'm going to have to stump up for the fronts eventually.
I'm convinced it's at the front though, as over speed bumps the front bounces more than glides, the rear tends to appear more softly sprung, but that could just be my saggy butt.
I guess, if it still doesn't fix it, at least I'm buying peace of mind for a few years on the suspension.
Post #711281 6th Feb 2025 11:31pm
TorontoDee
Mine came to me with Arnott's already on the front as of December 2019. I've since had to replace the sway bars and bushings. I also replaced the rear with bilsteins about a year ago (which have been perfect). 2012 Supercharged L322
Post #711284 6th Feb 2025 11:46pm
GraemeS
Australia
I have Bilstein rear CVDs which were fitted several months before the fronts were changed and I have no complaints with the performance of any. However Bilstein rear air-springs don't extend the extra distance of the later L322 shocks, with both torn apart in a short time even though Bilstein shocks were fitted.
Mine's shocks were worn-out by 80K kms although I persisted for another 20-40K kms, wanting to delay the inevitable expense.
Post #711288 7th Feb 2025 12:27am
AndyRoo
My problem looks like it's the front end, I disconnected one of the turrets and drove around the block, the front seemed much the same, but the rear was noticably much harder.
Have to start poking around the front I guess, all new pads going in so that's an ideal time to dig in.
Post #711307 7th Feb 2025 11:35am
AndyRoo
I've decided rather than going all out I'll change the 2 front Height sensors, as I've read a number of posts where that turned out to go someways to fix the problem.
If that doesn't work, then I'm afraid its 2 front struts.
Any views on Aerosys or ProEvo+ versions of the struts with CVD, varying opinions from way back, but any recent anecdotes, Sam of Sam's Motor & Machine used Aerosys and they seem to be OK quality, ProEvo+ no experience of at all ?
Obviously I'm not about to fork out over a grand for Dunlop, OE or Arnotts on the off chance.
Post #711743 13th Feb 2025 4:12pm
AndyRoo
Replaced both front height sensors today, fixed my harshness problem completely, now back to wafting. In the end I used Aerosus units.
Unfortunately I had to destroy the old ones to get them apart, the Torx machine screws weld themselves to the brass threaded inserts in the sensor body and the plastic is pretty weak, you need to recover the bolts as new sensors don't come with them so you need to hack away the plastic to be able to clamp the brass fixing to get the Torx out.
Both brackets quite rusty so cleaned them up and rustproofed before refitting using some copper grease, hopefully if I have to take them off they'll be easy to remove.
Did the usual height calibration and CVD calibration afterward, all good now, hopefully for a long while.
Noticed the NSF sensor was not smooth, so that was probably the dodgy one, the other was stiff, but smooth.
Also got me one of them there stickers, looking mighty fine.
Post #712232 19th Feb 2025 3:54pm
AndyRoo
OK, so here's an observation that I've seen today, but isn't logical but is happening.
Replaced the rear height sensors as getting quite miffed with the deteriorating ride quality, harsh damping, crashing over bumps etc, but they made no difference at all from what I can tell.
What I did notice was that when I tried the suspension CVD calibration in the GAP tool, that 10 second scan part, at various speeds and surfaces all came out with the same hashness and no descernable difference even when redone on silky smooth fresh tarmac.
In frustration I calibrated it again just sat in the car park whilst pondering the problem, straight & level, engine running in drive, held on the brakes. What a transformation going out onto a fairly broken and bumpy road the ride is transformed and gloriously smooth.
No crashing, no overdamping, just smooth wafting, I can hear the patter of the broken surface but I'm not feeling it, or every bump in the road any more.
Odd, but true. Is it just my car, or have others seen similar ?
Post #723697 31st Aug 2025 11:31am
JayGee
I’ll try that. Always done the calibration on the move but also came to the conclusion it wasn’t actually a calibration? Agree that sticky height sensors can be the cause of a harsh ride. Mine’s currently very comfortable and seems even better at the ‘high load’ tyre pressure settings. I replaced all 4 struts about 18 months ago BTW 2012 TDV8 Vogue (L322)
Post #723709 31st Aug 2025 5:18pm
