![]() | Home > Technical (L322) > P040D-00 (2F) EGR temperature sensor replacement |
Joe Loughlin Member Since: 19 Mar 2025 Location: Hertfordshire Posts: 3 ![]() ![]() ![]() |
Sweet
JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 254 ![]() ![]() ![]() |
Having read through this with interest and hopefully not having to do it on mine in the near future, it seems that the heat shield bolts are a big part of the job.
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
This tool has a good review and could be the solution.
Ok
j9ffy Member Since: 27 Mar 2018 Location: Indre Posts: 40 ![]() ![]() ![]() |
Likewise - no recurrence for me (fingers crossed). |
Did you get this sorted? |
Aviator Member Since: 11 May 2025 Location: Berkshire Posts: 12 ![]() ![]() ![]() |
After doing a fluid change on the gearbox and being sat for 10 or so mintes at 2k revs. I had the DPF full visit dealer warning come up. The way I got around the DPF being blocked was to use the diagnostic scanner to tell the ECU that I had replaced the DPF and then I forced a regen. I had 2g of soot after a short drive on the M4. Havent seen the warning again since |
