Home > Technical (L322) > P040D-00 (2F) EGR temperature sensor replacement
Page 11 of 11 <123 ... 91011
GGDR
Ah Joe you\re welcome.
Welcome of the club Smile
Well done to you, it's a job
. Cheers, Greg
Post #715675 6th Apr 2025 7:38pm
Joe Loughlin
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Sweet
Ill share any progress
Or come back for therapy if none of it works lol
Post #715681 6th Apr 2025 9:45pm
JonnyCJ
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Sumatra Black
Having read through this with interest and hopefully not having to do it on mine in the near future, it seems that the heat shield bolts are a big part of the job.
I’ve therefore thought of a potential solution which may or may not work.
Given that the heat shield aperture only needs to be opened a few mm, could you use the special tool over the sensor once the wires have been chopped and then slide a core cutting bit over the special tool, so it acts as a guide and then use your fingers to oscillate the core bit until you’re through the heat shield? Appreciate that the special tool may only go on a bit, but it’s just there as a guide.
Post #715937 11th Apr 2025 7:17am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
This tool has a good review and could be the solution.
 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #715993 11th Apr 2025 10:16pm
Joe Loughlin
Ok
So I spent all Saturday forensically putting in the new sensor, and man it was the most nerve racking, awkward and apprehensive job on a car I’ve ever done!…. But I got it done, phew.
While I had the bonnet open I removed the donut plenum, egr pipe and throttle body and cleaned out all of that nasty black gunk that had accumulated up there and changed the egr temperature sensor on the top egr pipe. In addition I changed the boost control solenoid on the big turbo (nice easy job) as this had also been identified as bad on my diagnostic scanner. Now all of those codes have successfully cleared and don’t return 👌🏼
However, after restarting the car and chasing & sorting any air leaks, the old symptoms came back with the car going into limp move after an attempted rev & now I’ve got red dashboard warnings for blocked DPF filter of which is confirmed by my scanner 😩
Has anyone experienced anything similar & any recommendations on how to clean the DPF if that’s the problem……any pointers will be greatly received and I’ll update any success
Post #716108 14th Apr 2025 7:24pm
j9ffy
France 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
GGDR wrote:
mine is perfect from what was it 3 years ago
Likewise - no recurrence for me (fingers crossed).
Post #718812 30th May 2025 12:36am
j9ffy
Joe Loughlin wrote:
Ok
Did you get this sorted?
Post #718813 30th May 2025 12:37am
Aviator
Joe Loughlin wrote:
Ok
After doing a fluid change on the gearbox and being sat for 10 or so mintes at 2k revs. I had the DPF full visit dealer warning come up. The way I got around the DPF being blocked was to use the diagnostic scanner to tell the ECU that I had replaced the DPF and then I forced a regen. I had 2g of soot after a short drive on the M4. Havent seen the warning again since
Post #718815 30th May 2025 6:28am
Grp23!
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Epsom Green
So I have the same code on my Gap iid. When I clear faults it's the only one that comes back. Occasionally I'll have restricted performance but also the car will kill the engine when trying to drive away. Usually if I clear the faults and do a few start stops it allows me to drive normally without any other issues. Today though it took loads of try's before it finally allowed me to drive the car, obviously with it stopping the engine this is problematic. Will changing this sensor cure this, has anyone else had the issue with the engine cutting out. Happy to replace the sensor just wanted to find out if anyone had the same issue with the engine cutting out. Many thanks
Post #723993 5th Sep 2025 10:34am
