![]() | Home > Technical (L405) > ADBLUE reading service menu |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 153 ![]() ![]() ![]() |
When I bought my L405 I asked the dealer as part of the sale to top off the AdBlue tank which they did but the car did flag inferior quality and it got through the tank particularly quickly. I bought some AdBlue in from Screwfix and filling the tank with that ended the inferior message and its consumption was much less per 1k miles driven.
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 507 ![]() ![]() ![]() |
I have the SDV8, but I think the tank is the same. It can take time for the filling to register. Does the menu have an amount to fill up?
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1417 ![]() ![]() |
I did read somewhere not to overfill the tank due to level sensor issues. 2018 SE SDV8 4.4 Byron Blue |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1832 ![]() ![]() ![]() |
I would do a drain & refill, a DIY job if you’re up to it, and you have an iiD tool to do the pump pressure test and reset. Best to get all the old sh*tty fluid out rather than mix it with the new.
cbrman599 Member Since: 03 May 2025 Location: hull Posts: 11 ![]() ![]() ![]() |
Hi all thanks for the replies - I put around 7 LTRs in. The 515 miles to no restarts message has popped up today. It's my first RR and not very confident to drain and refill myself. I think likely get it booked in with a local specialist? |
From WS Manual it looks like your level sensor has failed or you have an air lock.
hi
Everyone has their favourites but if its a cheap reader that also clears/reset DTC then you cant go wrong with a Autel AP200
Thanks very much I will have a look at that. |
have ordered the code reader thank you |
I have bought this now and linked it to the app on my mobile. Do I need to download anything ref land rover etc or just plug it into the car ? |
Hi all
I presume you have followed the following quick start guide? and read the operating manual for the tool?
