Home > Technical (L322) > Difference Between L322 and L405 Deployable Step Motors
Stuart-
I've been perusing various listings here and in China on deployable step motors. I'm seeing some mismatches in data on the Chinese listings. Most are showing L322 from 2013 on, and as we all know, after 2013 is the L405.
As everyone pinches each other's photos online, photos may be unreliable. So I need some first-hand knowledge, please. It seems the L322 and L405 motors differ, but not by very much?
I ordered a couple in to see what they are like, here's one of them.
This seems to be an L405, but looking at genuine photos of L322 ones, I don't see a lot of difference. Can someone confirm they actually are different? And/or what differs? 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
1991 Mercedes 420 SEL
Post #707189 18th Dec 2024 2:23pm
Sorry Stuart I have no idea… We only ever change the complete hinge assembly…
Post #707238 19th Dec 2024 5:07pm
GGDR
does anyone know where to get a "wedge key" ?
. Cheers, Greg
Post #707256 19th Dec 2024 9:15pm
From a wedge shop?
Ill get my coat Embarassed Whistle Thumbs Up
Post #707262 20th Dec 2024 2:34am
Someone's getting better Laughing Wink ... - .- -.
Post #707272 20th Dec 2024 9:57am
Laughing Thumbs Up Bow down
Post #707277 20th Dec 2024 12:08pm
Stuart-
GGDR, you've got yours off at the moment IIRC? Any chance of some photos if I DM you an email address? 2017 4.4 SDV8 Autobiography in black
Post #707279 20th Dec 2024 12:45pm
GGDR
Hi Stuart, sorry I missed this no not got steps off but this I think shows key in place vs key missing
 Cheers, Greg
Post #710565 29th Jan 2025 9:14pm
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
I’ve got some off the car for my L405 if you need any photos.
Post #710581 30th Jan 2025 7:04am
Stuart-
It's the L322 ones I need photos of really.
The plot thickens. I've just received some more in, bought in as L405/L494. Same as the ones I have and have been selling already.
They are labelled LR0044808 and LR0044807, which are L322 numbers.
So I need to know still, are the L322/405/494 actually all the same, or is it a Chinese incorrect labelling issue?
Edit: I did find a previous topic on this that suggests they aren't quite the same, but can be adapted. 2017 4.4 SDV8 Autobiography in black
Post #711022 4th Feb 2025 2:44pm
Stuart-
And I just got some step hinges in that have this fixing kit with them. See this topic.
Is this the wedge key spoken of? 2017 4.4 SDV8 Autobiography in black
Post #712355 20th Feb 2025 11:58pm
GGDR
the small piece with the bolt in it - maybe Stuart
. Cheers, Greg
Post #712364 21st Feb 2025 6:47am
Stuart-
I've now got to the bottom of this. The motors are almost identical, but there's a slight difference in the cut-out on the bar, and the bar rests in a different position. It's easy to see why so many suppliers confuse the two — even holding one of each in your hand, the difference isn't immediately obvious.
I now have L322 motors in, same as original part numbers LR004807 and LR004808, and they can be had from my site >here<. 2017 4.4 SDV8 Autobiography in black
Post #718226 20th May 2025 2:58pm
98_Martin
I'm currently refurbishing some steps so an interesting thread for me.
Also first time I've seen your site so added to my bookmarks for future reference if I'm needing spares for the steps, very handy.
A quick question if I may. My car body side of the loom for the motor connectors are badly corroded (previous owner removed the deployable steps and fitted fixed steps in there place) as they were left zip tied up under the car without anything over the ends causing them to fill with crap. Anyway this has corroded the pins meaning I have the replace that length of the loom or repair what I have.
I wonder, is it possible to source just the connectors on the body side for the motor connection? Either with the appropriate pins or prewired with a pigtail to solder into my current wiring? It would save me from disassembling the interior to reach the next connector back for the wiring down to the motors as I could leave it in place and repair what I have.
Thanks! 2010 Range Rover Autobiography 5.0 SC
2005 Lotus Elise 111R
Post #718376 22nd May 2025 6:36pm
GGDR
98_Martin personally I would buy some of these kind of waterproof auto connectors.
Chop and replace both ends. They are quite easy to use.
I'm really after a pic of the "wedge key" is possible
https://www.ebay.co.uk/itm/395940024924?_t...p_homepage Cheers, Greg
Post #718398 23rd May 2025 11:14am
