Home > Technical (L322) > Fitting a new battery tomorrow, does it need coding in ?
Klunk
Hi, just bought a new battery and I’m making sure it’s fully charged using a ctek overnight.
When I fit it, does it need coding in ?
I don’t have a tool to do that so curious if I need one.
K
Post #718499 24th May 2025 5:39pm
Happydaze
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
I swapped the battery in my 2007 tdv8 without doing anything special or clever, without any problems.
Chris
Post #718511 24th May 2025 9:02pm
Klunk
Thanks, I should have mentioned, mine is a 2009 digital dash car.
Not sure if that makes a difference
Post #718515 24th May 2025 9:28pm
Full-fat-Lance
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Orkney Grey
I think the answer is that’s it’s preferable to tell the car it’s got a new battery, but isn’t essential and the car will learn over a short period of time.
Post #718517 24th May 2025 9:44pm
Klunk
Thanks,
I am fitting a new battery primarily to fix the random and erratic errors like no forward alert available, and such like.
The old one was completely discharged 3 years ago, but I’ve soldiered on with it.
As the errors have started to reappear more frequently, I reckon a new agm battery is a simple way to eliminate that as a factor before a service next week.
Post #718532 25th May 2025 8:42am
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
More important with AGM batteries from 2010 onwards
Less so with the lead-acid types from 2009 and before
Post #718544 25th May 2025 11:25am
Gsxr1250dave
Klunk wrote:
Thanks,
I fitted a new battery for the same reason I'm still getting the random erratic errors
Post #718578 25th May 2025 8:46pm
Goldstar
2011 Range Rover Autobiography TDV8 Stornoway Grey
I changed my battery last week and didn't do anything to code it to the car (60 plate 4.4TDV8).All working fine. Btw if you can convince Halfords that you should have a trade card you can get a decent discount off batteries. mine was £103 instead of £158
If you have the ECU in front of the battery with 2 security Torx 20 head bolts holding it in and one is rusted in and won't move (like mine) you can get a 10mm on a 1/4' ratchet with extension onto the single bolt that holds the ecu bracket to the body and remove it that way with a bit of bending of the bracket for access Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey.
Post #718658 27th May 2025 6:37am
