Home > In Car Electronics (L405) > A few connectivity questions
Page 3 of 3 <123
Kot
Hoping it wasn't going down that route, do you have warranty?
Look at my comments in this thread when I had TCU issues
https://www.fullfatrr.com/forum/topic67290.html 2018 SE SDV8 4.4 Byron Blue
Post #682056 7th Jan 2024 11:44am
To be honest, I can do without the live stuff, since I can use Waze through CarPlay and the InControl stuff works fine, so I’m not missing anything I had previously.
Given what the TCU does, I’m not inclined to change it and the likely ensuing hassle and cost.
I don’t have a warranty, so that definitely puts a nail in that particular coffin I reckon. Rolling Eyes Got - 2017 SDV8 Autobiography in Loire Blue
Post #682067 7th Jan 2024 3:47pm
Kot
Maybe you will be lucky just a VSS update is all that will be required? 2018 SE SDV8 4.4 Byron Blue
Post #682075 7th Jan 2024 5:05pm
Possibly, I’ll ask my local Indy if that’s something they are able to do. Got - 2017 SDV8 Autobiography in Loire Blue
Post #682086 7th Jan 2024 6:29pm
Gremlin500
Hi Alan,
Sorry you’re still having trouble Sad
If you can get the Indy/ Dealer s/w update to S22A through Pathfinder this could fix the problem, but otherwise it looks like replacing the TCU Shocked V6 Vogue - “Less is More” - less to go wrong!
Post #682117 8th Jan 2024 12:01am
Thanks Gremiln, I’ll ask the question but I’m not inclined to pursue it any further if that doesn’t fix it.
As I say, I won’t miss what I haven’t had Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #682119 8th Jan 2024 12:08am
robmeister1969
United Kingdom 2018 Range Rover Autobiography SDV6 Corris Grey
Sorry to pick-up on an old thread, but wondering if you ever managed to resolve this?
Post #717518 6th May 2025 8:15pm
Unfortunately not, no. Got - 2017 SDV8 Autobiography in Loire Blue
Post #717519 6th May 2025 8:20pm
robmeister1969
If I figure it out, I’ll let you know.
Just picked up a 2019MY last week, and can’t see my home WiFi or connect to iPhone/ sim.
Was going to try battery disconnect and unplugging the telematics module in the first instance. Current > FFRR 2018 3.0 SDV6
Past > RRS 2015; RRS 2005; RRS 2007
Post #717522 6th May 2025 8:24pm
I wish you luck. I did manage to get connected once but it didn’t last. Got - 2017 SDV8 Autobiography in Loire Blue
Post #717523 6th May 2025 8:25pm
robmeister1969
Brief update - my Wi-Fi and SIM card have not been working on my Range Rover which I recently purchased secondhand. Tried various resets without success.
Purchased a secondhand TCU from eBay for £50 . Switched out the TCU and found that Wi-Fi worked fine. Did try a couple of SIM cards from my mobile phones. Not sure if there were specific issues with the SIM cards, and didn’t mess around with them too much but they were not working but did seem to make more progress than before the TCU swap. Think they might need to be left alone for an hour or 2 to pick up a signal?
Used my scanner to try to adapt the secondhand TCU to my VIN, but it doesn’t have that function. Notwithstanding, thought I would see how I get on with the secondhand TCU, but then of course discovered that the smart key was not recognised. Needed to switch back to the original TCU and unfortunately the Wi-Fi problem came back. Also, with the Wi-Fi working on the secondhand unit, I did try for software updates but there weren’t any available.
So I’ve confirmed what the issue is, but not solved it as yet. I have read a couple of posts that suggest that Land Rover now have a software fix, but I need to give them a call to see if that is the case. Current > FFRR 2018 3.0 SDV6
Post #718614 26th May 2025 12:56pm
Good and bad news then. Since I have the remote app , I guess replacing the TCU would stop that working, so not a viable solution but at least you’ve proved the point.
It’ll be interesting to see if a s/w update becomes available, because my main motivation for this is to get an “over the air” update. Got - 2017 SDV8 Autobiography in Loire Blue
Post #718616 26th May 2025 1:10pm
robmeister1969
Agreed. When I tried to set-up InControl on my car, it wasn’t finding my VIN. I contacted LR and they said there was a problem (which I assumed was due to my connectivity issues) but came back to me a few days later having sorted it. They’ve given me 3 years of Secure Tracker! As I’m sure you know, there’s a separate SIM in the TCU.
I’m not sure there’s any great benefits to having WiFi working and I do have Apple CarPlay but these things niggle away at me until I get them sorted.
What I did find difficult was releasing the connection clips on the TCU and invariably breaking some of the clips when trying to take them off ! Current > FFRR 2018 3.0 SDV6
Post #718618 26th May 2025 2:48pm
I’m with you on the niggling aspect of this. It’s more of a “I want to prove this will work”, rather than using the feature.
I’m now getting issues connecting USB devices and CarPlay can also be temperamental at times, so I wonder if the issues is getting worse. Got - 2017 SDV8 Autobiography in Loire Blue
Post #718625 26th May 2025 4:03pm
Page 3 of 3 <123
