Home > Technical (L405) > front knuckle cracking
Page 50 of 57 <123 ... 495051 ... 555657>
Dolphinboy
Ive just taken my Nov 2015 L405 into LR MD to have this looked at. They told me anything before 2016 is an automatic swap for new. 2016 onwards, they inspect and change if necessary.
Post #713970 13th Mar 2025 2:38pm
dpm
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Corris Grey
Just an update, the car will be taken to Duckworths for inspection and part replaced and the other side done i hope, also profile updated thanks.
Post #713996 13th Mar 2025 8:04pm
Flash
Sweden 2015 Range Rover Autobiography SDV8 Kaikoura Stone
My21 affected?
Someone asked if this is an issue on late L405s. I found a picture of what seems to be a cracked knuckle on a my21 D350 Autobiography for sale in Italy. It looks similar to the crack on Christian and Veras car.
Pics in my gallery
Post #714669 23rd Mar 2025 2:48pm
dpm
Duckworths replaced both sides, service manager great to deal with.
Post #715753 8th Apr 2025 8:00am
beach_rr
United States
L494 - Cracked Knuckles Too
Hey everyone — just wanted to add my experience here.
I’ve discovered the same issue on my 2015 L494. I know this is an L405 forum, so sorry if this is off-topic, but both models seem to use the same part.
My driver’s side knuckle is nearly split in half, and there’s a small crack forming on the passenger side. This is a major safety issue. I recently bought the truck from a family friend, drove it 200 miles home, and now I keep thinking about what could’ve happened if the knuckle had failed at 70 mph.
The truck has a full dealership service history with every service done since new. It’s only got 50k miles, has been garage-kept, and is in mint condition. If there was ever a case for this being a manufacturing defect and not abuse or neglect, this is it.
I reached out to my dealership, who recommended contacting JLR Customer Care. The rep was helpful and suggested two things:
    File a report with NHTSA (U.S.)
    Have the truck flatbedded to the dealership for an official diagnosis. JLR will review the diagnosis to potentially cover the repair.
So far, the L494 isn’t included in the recall, but it’s a work in progress. I really hope JLR addresses this. The potential cost is frustrating, but it’s nothing compared to the risk of a catastrophic failure.
Thanks to everyone who has posted about this — it’s been really helpful. I’ve attached photos of my knuckles. (the passenger side is really hard to see the crack) If it's allowed, I’ll keep posting updates as I go through the process with the dealer and JLR.
Post #716753 24th Apr 2025 11:14pm
Happydaze
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Nice of JLR to spread these problems around the range!
Chris
Post #716774 25th Apr 2025 12:05pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Just out of interest, thought I would take a picture this morning at the revised design on my L460
Post #717051 29th Apr 2025 10:05am
Gremlin500
The split has gone! Also all curves, so no sharp-edged stress-raisers, what an admission of guilt!? 🤔?
I wonder if an L460 knuckle would fit an L405? Whistle V6 Vogue - “Less is More” - less to go wrong!
Post #717073 29th Apr 2025 1:38pm
mjdronfield
As, the post a couple up… my neighbors L494 knuckle split in 2022. It’s a 2015 model. He went through insurance to fix as it then wrecked loads of other bits underneath as he was driving it at the time.
He checked the other side a couple of weeks ago, still original and not replaced, and he could see a crack. He’s just paid like £1000 to get it replaced as JLR still saying there is no recall for the RRS. The mechanic tapped the bolt out and as he did the knuckle split there and then. How the hell can they decide the Sports not affected when it clearly is? I’m also not convinced it’s just a “batch” problem….. but have no evidence to disprove. Neighbour has kept the failed parts and invoice in the hope that JLR do what’s right for Sport owners.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #718152 18th May 2025 4:26pm
woodyrvf750
And another. 2017 SDV8
My car has an extended JLR warranty and went to Sytner Coventry to investigate a clicking noise on acceleration.
They first diagnosed an issue with the engine under tray which they said fixed the problem, which it did not.
I then took it back in and another mechanic diagnosed the passenger drive shaft which was replaced, then the front diff mounting bracket. Apparently you need to remove the hub to change the front diff bracket.
And no surprises, this happened.
My chassis ends 349643.
Post #718393 23rd May 2025 9:36am
cupples8267
Scotland 2016 Range Rover Vogue SE SDV8 Santorini Black
I had very small hairline fractures in one of my front knuckles. My car is outside of the recall range but LR MD got both sides replaced under extended warranty without issue.
Post #718626 26th May 2025 3:17pm
Mikey
In today for a set of front ARC pipes. Owner was unaware of any issues, or the outstanding recall. 15MY, so both sides to be replaced under warranty
No, I didn't road test it Neutral
Its coming back once the knuckles have been done Thumbs Up
Post #718645 26th May 2025 8:08pm
cupples8267
Further to my earlier post today, it was Mike at MMP who managed to identify the cracks in my steering knuckles/ hub carrier. Only very careful inspection of the rear edge after a wire brush. Thanks MMP for potentially saving a catastrophic failure.
Post #718646 26th May 2025 8:31pm
woodyrvf750
Mikey, do JLR provide an improved replacement part or is it identical, and therefore going to break again?
Post #718667 27th May 2025 8:40am
woodyrvf750
A threaded suspension ball joint with a nut on the end to hold it in place. Forgive me for stating the obvious but does anyone know why the 405 designers decided to try something new?
Post #718691 27th May 2025 5:26pm
