Home > Technical (L405) > 2019 L405 ATB LWB deployable steps not working - RESOLVED
Stuart-
The step only sits on the hinges in like a half-inch recess, so if you lift it at the back, you should be able to manipulate it off.
Unless it has a body kit or US cars differ in some way. 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
1991 Mercedes 420 SEL
Post #719085 3rd Jun 2025 1:24pm
noone
United States
noone wrote:
Previous owner, original owner said he turned them off because it was hitting his shins and he’s 6’4”. I have no reason not to believe him. They just don’t turn back on.
Will check fuse.
Is there a fuse diagram somewhere? I found one but am wondering if it’s correct.
Which pin is power on the DCSM connector? Red wire? Can I just check for 12v on the connector after pulling it out of the DCSM? 2023 L460 Range Rover SE P400
2019 L405 Range Rover ATB LWB
Post #719166 4th Jun 2025 9:25pm
Kot
Loadspace fuse box
F39 is a 30A fuse https://www.ownerinfo.landrover.com/docume...5/G2191471
Also same fuse box there is Fuse link FL1 (top left) for deployable steps and probably deployable towbar Module.
I had an issue once with a frozen amp and by pulling the fuse and replacing same it did nothing, but when I pulled the associated Fuse Link it reset the module. Maybe you will be lucky and thats all it is?
Here is the diagram below showing F39 and FL1 feeding module
https://www.fullfatrr.com/gallery/albums/u...earJB3.pdf 2018 SE SDV8 4.4 Byron Blue
Post #719208 5th Jun 2025 4:00pm
noone
United States
Thank you. I had already pulled F39 (it’s a 15 amp fuse in my 2019) and it was fine. I’ll check the F1 fuse! 2023 L460 Range Rover SE P400
Post #719232 5th Jun 2025 8:20pm
Kot
Its FL1 by the way not F1 Thumbs Up 2018 SE SDV8 4.4 Byron Blue
Post #719251 5th Jun 2025 9:59pm
Kot
Here is the outputs for the module
https://www.fullfatrr.com/gallery/albums/u...owbar1.pdf 2018 SE SDV8 4.4 Byron Blue
Post #719255 5th Jun 2025 10:24pm
noone
United States
Latest update:
Bought a used deployable steps control module. I unplugged the old one and then plugged into the new one ( I did not remove the old one yet, so it was in a vertical position, if that matters).
As soon as I plugged into the second plug, both steps deployed!
But.... I go to the screen and go on deployable steps and it's doing the same thing - I press power and then it goes in to the menu, then goes back to powered off.
I checked the F39 fuse and it looks like it's still good.
Next steps?
I am going to try and remove the spare tire liner so I can get a good look at the wires and maybe twist them, But alas, now the left seat is not folding down. I'll open another thread on that. 2023 L460 Range Rover SE P400
Post #721051 9th Jul 2025 3:26am
noone
United States
Should I see a RBM ECU when I scan my car? I do not and I'm wondering if the module was left out by the dealer at some point. If anyone could scan their L405 with DSS, would be appreciated. 2023 L460 Range Rover SE P400
Post #721575 19th Jul 2025 2:57pm
noone
United States
To close the loop in this, exact same problem as described by multiple threads in this forum. When the previous owner took it in for service at the dealer in his city, they removed the deployable steps programming by accident. My local main dealer got me sorted and reprogrammed free of charge, which thoroughly surprised me. 2023 L460 Range Rover SE P400
Post #722337 5th Aug 2025 4:06am
