![]() | Home > Technical (L405) > 2019 L405 ATB LWB deployable steps not working - RESOLVED |
noone Member Since: 05 Apr 2025 Location: Florida Posts: 96 ![]() ![]() |
Is there a fuse diagram somewhere? I found one but am wondering if it’s correct. Which pin is power on the DCSM connector? Red wire? Can I just check for 12v on the connector after pulling it out of the DCSM? 2023 L460 Range Rover SE P400 2019 L405 Range Rover ATB LWB |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1422 ![]() ![]() |
Loadspace fuse box
Thank you. I had already pulled F39 (it’s a 15 amp fuse in my 2019) and it was fine. I’ll check the F1 fuse! 2023 L460 Range Rover SE P400
Its FL1 by the way not F1 |
Here is the outputs for the module
Latest update:
Should I see a RBM ECU when I scan my car? I do not and I'm wondering if the module was left out by the dealer at some point. If anyone could scan their L405 with DSS, would be appreciated. 2023 L460 Range Rover SE P400
To close the loop in this, exact same problem as described by multiple threads in this forum. When the previous owner took it in for service at the dealer in his city, they removed the deployable steps programming by accident. My local main dealer got me sorted and reprogrammed free of charge, which thoroughly surprised me. 2023 L460 Range Rover SE P400
