![]() | Home > Maintenance & Mods (L405) > Executive rear seat storage lid fatal demise |
noone Member Since: 05 Apr 2025 Location: Florida Posts: 97 ![]() ![]() |
Good to know!! And it looks like it’s all hidden which is great. 2023 L460 Range Rover SE P400
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 507 ![]() ![]() ![]() |
Thx. So it’s the plastic lid under the leather armrest top. Appreciate you taking a picture of it. I would buy the part if it was available, but I can’t find it. Guess I’ll have to MacGyver it with metal zip ties and epoxy. 2023 L460 Range Rover SE P400
CerebralThunder Member Since: 16 Mar 2022 Location: Midlands Posts: 31 ![]() ![]() |
Did something similar to @Swagman, seems to be holding. What a ball-ache though..
Did you epoxy it after you zip tied it together? I’m thinking I can use plastic zip ties, tighten them super tight with rolling a needle nose pliar, then dab epoxy on all sides.
I just put the 2 halves together for each section and zip tied them with the metal ties. I have a metal tie gun that I used to make sure they were very tight (and it cuts them flush). 2021 L405 Range Rover 'Fifty' D350 |
Is this the one to buy? Will the zip tie connection clear the bottom when the lid pivots up? https://www.amazon.com/FACTORAY-Stainless-...8&th=1 2023 L460 Range Rover SE P400
Mine is more like this (it's more expensive but I have access to them with my job):
Thx. And I assume the metal zip ties are all one size it looks like. I just need the tool to last 4 times of zipping. 🥴 2023 L460 Range Rover SE P400
Swagman Member Since: 03 Mar 2025 Location: Northampton Posts: 10 ![]() ![]() ![]() |
Nice neat job @CerebralThunder,
How did you remove the center console? By unscrewing/unplugging the whole thing? Or just the lid? 2023 L460 Range Rover SE P400
Just the lid and the tray under it, once you've unclipped the leather covering it (that is attached to the rear boot panel), you'll see a couple of screws |
Thx, stupid question but how does it unclip? Do you have a picture of the flap? Are there two folds on the leather piece and I just push/pull it through? 2023 L460 Range Rover SE P400
