![]() | Home > Maintenance & Mods (L405) > Executive rear seat storage lid fatal demise |
noone Member Since: 05 Apr 2025 Location: Florida Posts: 60 ![]() ![]() |
Good to know!! And it looks like it’s all hidden which is great. 2023 L460 Range Rover SE P400
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 505 ![]() ![]() ![]() |
Thx. So it’s the plastic lid under the leather armrest top. Appreciate you taking a picture of it. I would buy the part if it was available, but I can’t find it. Guess I’ll have to MacGyver it with metal zip ties and epoxy. 2023 L460 Range Rover SE P400
CerebralThunder Member Since: 16 Mar 2022 Location: Midlands Posts: 27 ![]() ![]() |
Did something similar to @Swagman, seems to be holding. What a ball-ache though..
Did you epoxy it after you zip tied it together? I’m thinking I can use plastic zip ties, tighten them super tight with rolling a needle nose pliar, then dab epoxy on all sides.
I just put the 2 halves together for each section and zip tied them with the metal ties. I have a metal tie gun that I used to make sure they were very tight (and it cuts them flush). 2021 L405 Range Rover 'Fifty' D350 |
Is this the one to buy? Will the zip tie connection clear the bottom when the lid pivots up? https://www.amazon.com/FACTORAY-Stainless-...8&th=1 2023 L460 Range Rover SE P400
Mine is more like this (it's more expensive but I have access to them with my job):
Thx. And I assume the metal zip ties are all one size it looks like. I just need the tool to last 4 times of zipping. 🥴 2023 L460 Range Rover SE P400
