Home > Technical (L322) > Transfer box fault
nigor
Estonia 2012 Range Rover Vogue TDV8 Java Black
Transfer box fault
Hello
I bought range rover L322 2003 with 3.0 TD6 for my girlfriend and low range has never been worked, i thought it is just transfer box motor but i removed it, tested and cleaned (Just like powerfuluk video) Everything seems to work in bench but when i select neutral and pull low range button it doesnt do anything. Earlier this year it did show "select neutral" text on instrument panel when car was started but now anymore.
On iidtool i read fault codes it gives
0x5230 Motor A and B off, A short circuit to ground
0x5234 Motor A and B off, B short circuit to ground
0x5238 Motor A and B open load
And TCM gives "0x99 CAN bus transfer box range error: general fault"
Instrument pack gives code 0x8D transmission interface bus fault
Is transfer box ecu toasted?
ECM gives p0380-80 Glow plug relay failure - glow relay defective and P1180-01 Low side fuel pressure sensor plausibility (fuel filter) - reduction in quanity due low pre pressure. I guess i need to change glow plugs and fuel filter also.
Post #607333 26th Sep 2021 5:10am
nigor
I changed new glow plugs and fuel filter and those engine ecu faults disappeared. But low range doesnt work and i dont know what to do.
Post #609078 13th Oct 2021 11:32pm
stuart_2006
I've got a 2nd hand transfer box ECU for the TD6 if you want to try it. I think I paid around £50 - if it fixes your problem then pay, otherwise send it back to me. But the problem I had was the transfer box motor. Got a recon one where the internal sensor has been replaced with a new improved design - think the chap sales on eBay now. Send me a PM if interested.
Post #609221 14th Oct 2021 11:01pm
stuart_2006
How did you get on replacing the glow plugs by the way? Were they a pain to remove?
Post #609222 14th Oct 2021 11:02pm
nigor
Removing intake manifold. It is quite easy. 4 of them was easy but 2 just unscrewed bolt off and core of glow plug stayed. Then i left it running and did few drive arounds and they popped out.
Post #609704 19th Oct 2021 12:47pm
natasayar
Turkey 2004 Range Rover Vogue Td6 Epsom Green
Re: Transfer box fault
nigor wrote:
Hello
Hello , i have 2004 L322 3.0 td6 and I had exactly same fault codes with you. Did u solve that problems?
Post #698037 14th Aug 2024 6:42am
Markske
Netherlands 2004 Range Rover Vogue 4.4 V8 Java Black
Hi Natasayar and Nigor,
Did you find out what the problem was? I have exactly the same issue. My shift motor and potentiometer work perfectly.
Kind regards,
Mark.
Post #720479 28th Jun 2025 1:18pm
p38arover
Australia
^^ Mark, are you sure there are no cracks in the potentiometer soldered joints? Mine had cracked joints. I resoldered them and that cleared the problem. That was 3-1/2 years and 25,000km ago. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #720481 28th Jun 2025 1:36pm
natasayar
Kind regards,
Mark.
Hello,
I found the problem and fixed. I disassembled the trasfer box motor unit. Tested with right pins like showed in the video of powerfulukltd. It was working but still have same error codes. Then i noticed copper cables of electric motor carbon brush touching the metal cover outside of motor. I arrenged the cable routes. And mount again. All worked nice. Hope it helps you too
Post #720483 28th Jun 2025 2:26pm
Markske
Thx Natasayar, this info is very useful. I right away get started to find out. Still is a mystery why the motor spins on the bench when directly connected to the battery 🤔
Post #720487 28th Jun 2025 2:58pm
Markske
Thx for the advice. I have already figured out that this is not the problem. Potentiometer readings are good. From 1.4 KOhm to 4.8 KOhm when I slightly turn the inner ring for about 340°.
Post #720489 28th Jun 2025 3:15pm
Markske
Problem solved.
The transfer case motor or the potentiometer wasn't the problem like I said before. It was the transfer case ECU due to water ingress and it was to much damaged to repair. Don't know how it's possible because the ECU is covered in a black plastic box behind the battery. Anyway, connected a second hand ECU and all works perfectly fine now. Shifting between high and low range goes smoothly and the low gear light on the dash extinguish when shifting to high gear. Hopefully everybody with this particular problem is helped with this reply.
Kind regards, Mark.
Post #721585 19th Jul 2025 6:29pm
