![]() | Home > Technical (L322) > Transfer box fault |
nigor Member Since: 28 Jan 2020 Location: Tallinn Posts: 13 ![]() ![]() ![]() |
I changed new glow plugs and fuel filter and those engine ecu faults disappeared. But low range doesnt work and i dont know what to do. |
stuart_2006 Member Since: 18 Jul 2018 Location: Holsworthy, Devon Posts: 132 ![]() ![]() ![]() |
I've got a 2nd hand transfer box ECU for the TD6 if you want to try it. I think I paid around £50 - if it fixes your problem then pay, otherwise send it back to me. But the problem I had was the transfer box motor. Got a recon one where the internal sensor has been replaced with a new improved design - think the chap sales on eBay now. Send me a PM if interested. |
How did you get on replacing the glow plugs by the way? Were they a pain to remove? |
Removing intake manifold. It is quite easy. 4 of them was easy but 2 just unscrewed bolt off and core of glow plug stayed. Then i left it running and did few drive arounds and they popped out. |
natasayar Member Since: 14 Aug 2024 Location: Turkey Posts: 4 ![]() ![]() ![]() |
Hello , i have 2004 L322 3.0 td6 and I had exactly same fault codes with you. Did u solve that problems? |
Markske Member Since: 28 Jun 2025 Location: Netherlands Posts: 5 ![]() ![]() ![]() |
Hi Natasayar and Nigor,
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
^^ Mark, are you sure there are no cracks in the potentiometer soldered joints? Mine had cracked joints. I resoldered them and that cleared the problem. That was 3-1/2 years and 25,000km ago. Ron B. VK2OTC
Hello, I found the problem and fixed. I disassembled the trasfer box motor unit. Tested with right pins like showed in the video of powerfulukltd. It was working but still have same error codes. Then i noticed copper cables of electric motor carbon brush touching the metal cover outside of motor. I arrenged the cable routes. And mount again. All worked nice. Hope it helps you too ![]()
Thx Natasayar, this info is very useful. I right away get started to find out. Still is a mystery why the motor spins on the bench when directly connected to the battery 🤔 |
Thx for the advice. I have already figured out that this is not the problem. Potentiometer readings are good. From 1.4 KOhm to 4.8 KOhm when I slightly turn the inner ring for about 340°. |
Problem solved.
