![]() | Home > Maintenance & Mods (L322) > Swollen wheel nuts |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Worth a try for £70
| andyrosehome Member Since: 06 Jan 2018 Location: South Wales Posts: 26
I bought a 2017 set of genuine RR alloys for my 2005 L322 so had to replace the wheel nuts with the later 23mm diameter type. I bought the stainless steel capped nuts but 2 weeks later I had a puncture and the tyre bay used a rattle gun on the new nuts. After the event I noticed that the new nuts on that wheel were already crucified where the hammer action of the gun had rotated the outer stainless cap on the inner solid nut causing bad distorsion to the point that I had to hammer a smaller size socket onto the nuts just to remove them. I replaced the 4 damaged nuts with new. Ever since then I have never used a rattle gun on them and always torqued to 140nm and all of the nuts are still perfect after 7 years, and I swap my summer & winter wheels twice a year. So I am 100% certain that it is not corrosion or frost or anything else that kills the capped nuts, it is the dreaded rattle gun. To the extent that if a tyre bay or garage won't remove and fit by hand then I go somewhere that will.
| kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1364
I've got the solid stainless nuts, and the manufacturer states not to use a rattle gun to prevent marring them. Obviously you can but I think it would ruin the looks of them. |
| Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1057
I fitted these off the bay.
Thanks KevinP I will keep that in mind. I don't plan to hammer them off and on with the gun to be honest. I'll still break the torque with a bar and re-torque with a wrench but the solid nuts will be a little more forgiving so I can set the rattle gun on a low torque to run them off and back on.
| All times are GMT |
