Home > Maintenance & Mods (L405) > 2018 SV clunk
Page 1 of 3 123>
zenman63
England 2018 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
2018 SV clunk
As above this new to me has a clunk on the rear, not all the time and does sound like something in the boot moving.
Car has full dealers history.
Does the E diff make a noise?
Only does it moving off and not all the time?
Post #721352 15th Jul 2025 9:17pm
Dolphinboy
fuel slopping around in the tank ?
Post #721355 15th Jul 2025 9:35pm
zenman63
No it’s something moving.
Does the E diff make any noise?
Post #721361 15th Jul 2025 10:33pm
chicb
United Kingdom 2018 Range Rover Autobiography TDV6 Barossa
Possibly the transfer box needing a double flush. Lots of posts on that here. Clonking when taking off, like something in the boot. Once moving it vanishes. I had that took it into Mikey couple of weeks back, double flush, recalibrate something, noise gone. Early days but seems positive. Used to drive me nuts Big Cry
Post #721370 16th Jul 2025 8:12am
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Mine does have a clunk too . Had in to MD who advised all 4 ARC bushes were shot and were the first port of call. Replaced all 4, made zero difference. Weird thing is , my first 405 (2013) did something very similar, 3 clunks when pulling of from a standstill, and sometimes on a rolling take off from a roundabout. It's way more pronounced with the newer one though, and just heard it when reversing in a parking space which is a 1st.
I know as soon as I book it in , it's open wallet time, I just don't know where to start. It has full S/H so all fluids have been changed to spec, however transfer case might be the logical starting point . 2019 SV AB Dynamic Scafel Grey
Post #721383 16th Jul 2025 10:16am
RRYorks
United Kingdom 2018 Range Rover SVAutobiography SDV8 Loire Blue
Hi
See my post
https://www.fullfatrr.com/forum/topic73369.html
Does it sound similar? I have not found the answer! 2018 4.4 TDV8
Post #721408 16th Jul 2025 4:25pm
zenman63
Hmm thanks for that.
Transfer box and both diffs just done at last service and I did have the issue associated with that on my last 4.4 and it fixed it, this is different, it’s like the rear is moving.
I need to find a garage with the ramp that has the shaker plates and have a look on the rear
Post #721416 16th Jul 2025 6:45pm
Mr Tee
RR YORKS - sent you a pm . Thumbs Up 2019 SV AB Dynamic Scafel Grey
Post #721431 16th Jul 2025 9:05pm
X1jimmie
United Kingdom 2017 Range Rover Autobiography SDV8 Aruba
I don’t have an answer for you but I think I have the same issue. I often hear it when accelerating onto a roundabout. Especially if I’ve been rolling up to it Previously owned: Range Rover L322 2007 TDv8 Vogue SE in Santorini Black
Post #721507 18th Jul 2025 3:38pm
zenman63
It sounds like a ball rolling in the boot, almost seems the diff is slipping.
I will change the oil again, it’s not long been done.
Post #721570 19th Jul 2025 1:51pm
M3bobby
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Fuji White
I have a 68 plate SV, 48,000 miles, had my rear differential and transfer case flushed a few months ago and I think it’s worse. Im now convinced the wrong oil has been used as there is a specific oil to use on the edif and not the type used on the L405 open diff. I’ve purchased the correct oil from LR and will do it myself this weekend and see if there’s an improvement. I’ve read lots of issues on the ediff and although most display the same symptoms, some are slightly odd, but is still down to the incorrect grade of oil.
Post #721745 22nd Jul 2025 10:02pm
X1jimmie
If it is the diff could this be tested by changing the terrain response mode? I.e. put it in sand mode and see if the noise is more/less apparent Previously owned: Range Rover L322 2007 TDv8 Vogue SE in Santorini Black
Post #721752 23rd Jul 2025 6:23am
Mr Tee
Never thought about that, mine has full MD history so has allegedly had all fluids changed to spec, but has never had a gearbox flush though.
Mibbe we need a group meet to discuss. Or I'll just book in with Mikey and be done with it ! Sure as snow falls of a dyke, he'll be unable to replicate as is the norm, mine was clunking like hell last night for a few minutes. Need to see if I can capture in a video which might prove hard though, need to get swmbo to do a take off . 2019 SV AB Dynamic Scafel Grey
Post #721755 23rd Jul 2025 9:25am
zenman63
I don’t think sand mode will work as it’s more random.
Driving more it does it less when hot so has to be internal to the diff.
It sometimes sounds like bump bump bump 3 times when cold so as above l might change the oil in it just incase LR put the wrong oil in.
Post #721756 23rd Jul 2025 9:26am
Mr Tee
100% 3 thumps from mine 2019 SV AB Dynamic Scafel Grey
Post #721759 23rd Jul 2025 10:25am
Page 1 of 3 123>
