![]() | Home > Technical (L322) > Td6 will not start! |
Maxxus005 Member Since: 16 Jul 2025 Location: Mjölby Posts: 5 ![]() ![]() ![]() |
My plan is , since there’s fuel pouring out of the return line , that the problem lies somewhere between the high pressure pump and the injectors, getting new o rings and copper washers on friday so gonna do a cleaning of them and the sockets. Also wanna check the fuel pump solonoid and the o ring on it. if all that fails i plan to take the pump out and check it/clean it/ change all the rubber stuff. 😃 |
so on my way down to the hp pump i noticed one of the smaller hoses being off..
steve k Member Since: 05 Apr 2024 Location: Berkshire Posts: 63 ![]() ![]() ![]() |
one hose is for the engine mounts, there will be a T piece further down the pipe where it divides off for the two mounts, the other hose is for the EGR. The leading pipe that appears intact goes across the engine to the 'reservoir tank' where there is an actuator to then feed the turbo vane actuator.
yup, had the injectors out for renovation plus testing, and theyre all working.
Landrange Member Since: 15 May 2025 Location: Oslo Posts: 11 ![]() ![]() ![]() |
So, after beeing back from italy after some weeks, its time to continue the trying to start work.
I handed over the car to a garage to sort this out, and he said it is the high pressure pump that is faulty.
Got the car back now, about time! It runs fine, and starts, if not wery quickly, but quick enough! L322 Td6
