Home > Technical (L322) > Td6 will not start!
Landrange
Norway 2002 Range Rover Vogue SE Td6 Epsom Green
I also got zero pressure, but diesel was coming out of the outlethose from the filter. Have no idea if it starts up when I have put everything back together! If it doesnt, then I`m not sure what to do! L322 Td6
LR 88 V8
Jaguar S-type V8
Triumph Tr8
Fiat 500
Post #721391 16th Jul 2025 12:01pm
Maxxus005
Sweden 2003 Range Rover Autobiography Td6 Zambezi Silver
My plan is , since there’s fuel pouring out of the return line , that the problem lies somewhere between the high pressure pump and the injectors, getting new o rings and copper washers on friday so gonna do a cleaning of them and the sockets. Also wanna check the fuel pump solonoid and the o ring on it. if all that fails i plan to take the pump out and check it/clean it/ change all the rubber stuff. 😃
Post #721394 16th Jul 2025 1:18pm
Maxxus005
so on my way down to the hp pump i noticed one of the smaller hoses being off..
looks like it comes from the egr cooler but not sure . do you know ?? Smile
Post #721664 21st Jul 2025 3:31pm
steve k
United Kingdom 2003 Range Rover HSE Td6 Giverny Green
one hose is for the engine mounts, there will be a T piece further down the pipe where it divides off for the two mounts, the other hose is for the EGR. The leading pipe that appears intact goes across the engine to the 'reservoir tank' where there is an actuator to then feed the turbo vane actuator.
I'm assuming you have already tested that the fuel injectors are getting firing pulses before embarking on all this work? Current: 2003 TD6 HSE
2004 Vogue SE 4.4
Previous: 1993 Classic 3.9
Post #721665 21st Jul 2025 4:51pm
Maxxus005
yup, had the injectors out for renovation plus testing, and theyre all working.
The port holes were fiiiiilthy 🤣🤣
Post #722022 29th Jul 2025 10:18am
Landrange
So, after beeing back from italy after some weeks, its time to continue the trying to start work.
I have put everything back in place now, but still no sign of it starting. Then its time to check the diesel return, or diesel leak off test. Do I take one off? Or all of the hoses? And put the ignition on, and then, there should be no diesel coming out?
By the way, I checked the secondary fuel pump, and its working. L322 Td6
LR 88 V8
Jaguar S-type V8
Triumph Tr8
Fiat 500
Post #722805 13th Aug 2025 8:07pm
Landrange
I handed over the car to a garage to sort this out, and he said it is the high pressure pump that is faulty.
Now he has changed it, but it takes some revs to get it started he says now. He will of course find out about it, but I`m thinking it might be the crank pos sensor? L322 Td6
LR 88 V8
Jaguar S-type V8
Triumph Tr8
Fiat 500
Post #724795 19th Sep 2025 11:48am
Landrange
Got the car back now, about time! It runs fine, and starts, if not wery quickly, but quick enough! L322 Td6
LR 88 V8
Jaguar S-type V8
Triumph Tr8
Fiat 500
Post #724913 22nd Sep 2025 12:35pm
